kinex vs crawford
Old Jun 30, 2004 | 06:56 PM
DaveO's Avatar
Re: kinex vs crawford
Rod,
What will the time frame be between your pre and post Crawford Plenum dyno sessions? IMO it takes a little running time for the ECM and front cylinder spark plugs to adjust to the equalized air flow.
DaveO
03 G35 AT Sedan / DP / Willow / Premium / Sport / Aero
350Z Air Duct, Eng Cvr & T-Stat / Stillen CAI
Crawford V-5 / GG 10-Wire Kit / TS ECM / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Jun 30, 2004 | 07:13 PM
mamboking's Avatar
Hold your horses with the kinetix plenum not cracking anymore comments. The V4 just started shipping so how can you say that they won't crack anymore. I am getting mine delivered next Tuesday. I'll post my experience with the product after having it at least a month. Then, if nothing happens we can proceed to say that they won't crack anymore but it is too premature to say that right now.
2004 G35 Coupe/OB/Graphite interior/Premium and aero package/Popcharger/Z tube/Hotchkis sways/Tein H-tech springs/Kinetix plenum/Crawford cats
Old Jun 30, 2004 | 07:18 PM
Raznips's Avatar
wel im not getting the plenum for a while now i think.. I was considering doing performance mods and then wheels, but i have decided that if i do wheels first, i can sell my stocks for >$1000 with tires and then get exhaust. then im only a small 1000 from being able to buy ts ecu and plenum together. I thinnk that im gonna hold off on plenum until ts comes out with the software for the 2004.5's because i dont want to run any risks running lean until they do.
2004 Black on Black g coupe 6spd.... <3 aluminum pedals, clear corners, z tube, and pop charger. From down south, houston tejas
Old Jul 1, 2004 | 11:44 AM
jjellyneck's Avatar
Dave,
I think that he did his stock dyno last week, though I beleive that he did not get an A/F measurement done.
'04 6MT coupe
Old Jul 2, 2004 | 06:05 PM
Rod's Avatar
Rod
DaveO, Dyno tomorrow at 9am that will make it 8 days and over 375 miles since plenum install and reset ECU....Rod
03 5AT-Premium-Aero-Tire & Wheel Pkg-Splash-Z tube-K&N Filter-32% Tint-10 wire Grounding Gear-Crawford Plenum Ver 5
Old Jul 3, 2004 | 11:53 AM
CookG35's Avatar
I just installed the Kinetix V4 last night. Pretty solid and fits like a glove. I'm not sure how this thing could ever crack, with the exception of heat cycling and getting brittle over time...but the lifetime warranty should remedy that. I like the fact I can keep my stock plenum because I trade cars often.
Old Jul 3, 2004 | 02:25 PM
DaveO's Avatar
Rod,
It took my TS re-flashed ECU (and front cylinder spark plugs?) a few days and over 100 "open loop" miles to fully adapt to the Crawford V-5's increased, balanced, air flow.
This delay was in line with most all of my car's other modifications. The one notable exception happened recently when I did back to back heat soak tests of the stock air case (with K&N filter) vs the Stillen CAI. The power lost by re-installing the stock air case was immediately noticable and did not come back over two days of hard driving. Re-installing the Stillen CAI brought back the power after a couple of hard test loop drives.
DaveO
03 G35 AT Sedan / DP / Willow / Premium / Sport / Aero / Mods
Old Jul 3, 2004 | 03:09 PM
fluffydot's Avatar
sorry, but what does "open loop" mean exactly?
When you say that it takes time for the car to "get used" to a new mod, do you mean the ECU adjusting for new air flow and A/F, timing etc?
or are you talking about your other things also?
if you have a TS ECU, shouldn't it be already mapped for your mods?
thanks.
Old Jul 3, 2004 | 10:13 PM
Rod's Avatar
Rod
DaveO, I have my pre and post plenum dyno results on a thread I just posted but you raise a good point. For what ever reason I didn't go pop charger and just went k&n filter. From your results I bet I could add to the gain I got from the Crawford plenum if I went away from the stock air box....Rod
Th611
Oct 27, 2015 03:48 PM
DRG35R
Sep 16, 2015 05:33 AM
G35Gnome
30
Apr 29, 2005 08:20 AM
Msedanman
Apr 23, 2004 03:02 PM
SoCalTed
Intake & Exhaust
Nov 19, 2003 08:17 PM
