strange problem, need answer
i will start with the beginin... i'm driving on a 90(km/h) road on fifth gear(shiftronic) and when i am going to shift a car , i realize that i will need more power so i downshift one gear and push the gas . now that the problem begin . three light goes on (service engine soon , slip and vdc off) ans reach the cut-off (redline) a 5k rpm ?!? . first thing i think was .. i will turn off the car and restart it . the car start normaly but thethree light are still on ...
3 or 4 hour later i went to star the car and it dont want to start . the only way i can start it is by pushing a litle bit the gas pedal (start without the gas pedal when is hot but long to start) . not so hot when you get in a g35 and it dont start normaly ?!! lol
i have try to unpluged the batery but nothing change , my car still have problem to start . what the hell can be the problem ? i will probably go to the dealer , gonna be expensive !!
or you can do the manual ecu reset. same as removing the battery to allow the ecu to reset but it can be done in under a minute. timing is the key
I had all my lights too when my friend screwed up some tuning but the manual reset did its job and lights all went out after.
03sedang35
Aug 29, 2015 07:56 PM
