New battery installed, engine stalls @ start-up
Old Mar 16, 2009 | 12:42 PM
jimmyc13's Avatar
I was getting the oil changed at NTB, as I had a coupon for that, as well as $ off for a new battery, so I finally got a new battery (104k miles on my original). It was only $10 more for them to install the battery, so I had them do it. Had the work done on Saturday & ever since, my car now stalls at startup. I need to give it a little throttle to keep it from stalling & then I'm good to go.
Is it possible they installed the wrong battery & can this be causing this?....or is it just coincidence? Any help would be greatly appreciated.
Thanks
Old Mar 16, 2009 | 01:07 PM
nghiars's Avatar
I'm pretty sure the battery/oil change was just conincidental with you car stalling at startup. Check out your MAF sensor. It may need to be replaced or simply cleaned.
Old Mar 16, 2009 | 02:15 PM
uf20wop's Avatar
could have low cold cranking amps
but lol @ paying someone to install a battery, even if it was $10
Old Mar 16, 2009 | 02:33 PM
05DGx's Avatar
I agree with this. Usually when your car does that, first thing you should check is the MAF.
Secondly....please stop taking your car to NTB. They're a bunch of wrench monkeys (for the most part), and the have a habit of doing things that are unnecessary.
Just about anywhere other than NTB or Jiffy Lube types of places are worth going to. Try to find a mechanic you can trust.
Old Mar 16, 2009 | 06:14 PM
jimmyc13's Avatar
Thanks for the tip, I've never taken my car there before...had some coupons for both services and I was in the area.
Old Mar 16, 2009 | 06:15 PM
jamisxc's Avatar
See the link below i posted a while back. Same problem with me. After changing the battery, the car stalls on warm start.
It seems like many people had the same issue after they changed the battery also. i did all the ECU reset, learning etc (before the cleaning) and it still stalled. It went away only after i cleaned the throttle body (wasn't at all dirty) and did all the ECU reset, learning stuff again.
i still have no idea why the problem went away after I cleaned the throttle body. The car was starting fine before the battery got changed.
https://g35driver.com/forums/engine-...-any-idea.html
Old Mar 17, 2009 | 04:31 AM
05DGx's Avatar
Did you do the throttle body calibration too? If so that might help the OP
Old Mar 17, 2009 | 04:32 AM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
10$ battery install? come on brotha..
Old Mar 17, 2009 | 05:31 AM
Strtsk8r321's Avatar
maybe they left the plastic over the contacts lol
Old Mar 17, 2009 | 02:38 PM
jimmyc13's Avatar
Wow, what a bunch of mature jokesters. Why do you care if I spent $10 for them to do it...it was a convenience. I'm married, 2 kids & have a hectic schedule. I've changed batteries on my past cars & just did my wife's car a month ago.
Old Mar 17, 2009 | 10:11 PM
lovemyg88's Avatar
only $10 for a battery change is a good deal imo. Come on guys, think about it, he was not taking his car to NTB just for a battery change. He took his car there for oil change, and since they offered him a discount, he got his battery changed as well.
Old Mar 19, 2009 | 01:38 PM
jimmyc13's Avatar
Thanks, glad you saw my side of it.
Old Mar 19, 2009 | 01:42 PM
WILLIE BEANS's Avatar
inferior battery ..???
chinee
Jun 10, 2024 07:48 PM
jsimonk
Dec 22, 2023 03:49 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
dimentio1
Aug 16, 2015 11:47 AM
chinee
Aug 8, 2015 10:11 AM
