Unhappy looking Dyno..
Old Apr 16, 2009 | 07:26 PM
muskamatt's Avatar
just curious but were you just doing a dyno for the fun of it or were you planning on getting a tune, btw how much is it to get dynoed at a shop?
Old Apr 16, 2009 | 07:31 PM
gizmo134's Avatar
im gonna install my SC setup soon, so i wanted a baseline so i could see what gains i get. im AWD, so the only place i could find out here that has an AWD dyno charges $65 for 2 runs, 10 bucks for each additional run, or like 120 for an hour. (they charge 55 for 2 2wd pulls)
Old Apr 16, 2009 | 07:37 PM
muskamatt's Avatar
thanks and good luck with the SC, which set up are you going with?
Old Apr 16, 2009 | 07:53 PM
OCG35's Avatar
Originally Posted by Q45tech
Each gear mesh adds 0.85% >1% frictional loss to drive train loss. So direct gear what ever gear that is, is optimum.
Common homework problems in college [mechanical engineering or any engineering].
http://www.geartechnology.com/pa/mem...5/section4.pdf
then its not some CA magic that makes 3rd gear result in higher numbers...
Old Apr 16, 2009 | 07:59 PM
OCG35's Avatar
Originally Posted by DaveB
Must be a California thing because elsewhere in the world, you'll usually see fractionally (and I'm talking less than 5whp) higher numbers when dynoing in a taller gear. I've seen this personnally on dynos (my cars and others) throughout Kansas City, the Midwest, and reported on this site, my350z.com, Maxima.org, ls1.com, corral.net, etc.
I frequent other sites... the only one you list that I am on is my350Z - I dont ever remember seeing dynos posted in each gear... in fact, I'm the only one I know of that has ever even posted 3rd gear and 4th gear back-to-back dynos.
Old Apr 17, 2009 | 12:32 AM
DaveB's Avatar
Huh? The lower the gear, the more friction. More teeth, more drag.
Old Apr 17, 2009 | 12:51 AM
DaveB's Avatar
https://g35driver.com/forums/tuner-d...hr-videos.html
Trey saw about 4whp/7wtq between running in 4th and 5th in BOTH his 05 sedan and his 07 sedan. Same day.
That's very much what I've seen with most every car I've witnessed that's tried this test.
Old Apr 18, 2009 | 01:06 PM
OCG35's Avatar
you popsted MT... we are talking about AT.
Old Apr 18, 2009 | 01:09 PM
OCG35's Avatar
but you stated 3rd only shows higher numbers on dynapack... if your statement above affected the numbers, then why would dynapack be any different?
Old Apr 18, 2009 | 01:15 PM
OCG35's Avatar
same day, same car, same dyno, same everything other than 3rd vs 4th gear... notice its a much grater difference than you posted from Trey MT
BTW, this is almost 4 yrs ago, so not what my car does today
3rd gear
4th gear
Explain why a roller dyno would be any different.
Old Apr 18, 2009 | 04:13 PM
DaveB's Avatar
Why would an automatic dyno differently than a manual? Your case is a rarity. Maybe
I didn't say that. I said on Dynojets you'll typically see higher numbers with taller gears. As for why it might be different on a Dynapak, the answer is easy. A Dynapak is a brake dyno. Adjust the brake and load and you can skew the numbers.
Old Apr 18, 2009 | 11:50 PM
OCG35's Avatar
skew the numbers
Anyway, I've dynod on 2 different roller dynos (1 of them 2 different times) and 2 diffent dynapacks (one of them 30 pulls and the other multipe different times, many many pulls)... I guess it was all just a fluke.
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Eomfd
Aug 29, 2015 12:42 AM
