Video of kinetix plenum
Old Jul 8, 2004 | 10:47 AM
fluffydot's Avatar
Re: Video of kinetix plenum
I have seen the video and the flexing was hard to make out... but I am willing to bet that any kind of flexing is bad.
also, I notice some of the movement you see is from the engine itself?
is that amount of movement normal? what rpm were you revving to?
sure looks scary from that angle...
Old Jul 9, 2004 | 11:15 AM
G4Teej's Avatar
How about using Imagestation.com or someplace like it?
www.imagestation.com
2003.5 Garnet Fire 5AT
Old Jul 11, 2004 | 04:51 PM
shortchaz's Avatar
After just watching mine what it does it at idle it is flexed and then when throttle is given it goes back to it's natural shape. I could barely tell that mine was even "breathing" at all and some of the movement I saw was from the engine moving in it's mounts(I think I want a torque damper). This one is definatly stronger than any of the previous ones and it also flexes less as well without the use of the middle bolts. Also to those that have already gotten a V4 and looked at it can you tell me if your's had an rectangular indention in front of the center post about 2-3 cm wide and 1.5 cm long, it was a couple inches away from the front of the plenum and just wanted to make sure that it is present in other's as well.
Best ET: 14.730 @ 96.14mph(stock)
2003 Black 5AT sedan
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
thechitoguy
Oct 1, 2015 05:25 PM
Red G Coupe
Video Share
Sep 28, 2015 06:29 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
