Does the '05+ auto VQ engine have oil consumption problems?
Old Apr 30, 2009 | 01:56 PM
Cali G's Avatar
I've read that the 'rev up' motor has oil consumption issues, and the rev up engine became available in 2005, but is the engine from a 2005+ automatic G35 a detuned 'rev up' or is it the non-rev up version?
Is oil consumption an issue for any automatic '05+ G35 coupes?
Old Apr 30, 2009 | 02:15 PM
vjquan's Avatar
OC is not an issue with non-revup motors. Short answer: No.
Old Apr 30, 2009 | 02:28 PM
Cali G's Avatar
cool, thanks for the 2 for 1 answer. I was wondering if it was a carry over non-rev up (vs. a detuned rev up) and if it had the OC issue.
Old Apr 30, 2009 | 02:36 PM
echang0501's Avatar
i think autos consume oil. i have an o6, i change the oil around 8k, I use mobil one ep. Im not sure if its because it's synthetic,(oil it guaranteed for 15k but i never go that high, i just don't trust it.) The oil seems low after like 6k. 1/4 off the dip stick. SO i top it off. But def. the oil is lower.
Old Apr 30, 2009 | 02:54 PM
Cali G's Avatar
Hmmm... is that just a unique experience though if the '05+ auto doesn't have the rev-up that has the TSB out for oil consumption?
Old Apr 30, 2009 | 05:08 PM
echang0501's Avatar
we don't have rev up. they have different motor's.
Old Apr 30, 2009 | 05:09 PM
SVTCOBRA's Avatar
IMHO, going beyond 3.5 or 4K you might see a little consumption in any car.....
I change my oil between 3 and 3.5K miles and have never seen any oil consumption in my Infiniti cars.
two 05 Sedans & one 04 Coupe (traded on of the 05 sedans for the coupe)
Do not believe there is any OC problems with the AUTO's.
Old May 7, 2009 | 04:53 PM
sheplex02's Avatar
OC is normal for our cars.. VQs are just like that.. you have a prob if youre consuming around a quart for every 1000 miles.. if youre not then youre fine...
easy check is if youre at the high mark and a 1000 miles later youre at low mark.. you have probs..
if your at mid way your borderline.. if its only a lil bit down after 1000 miles then your cool like a penguin..
Old May 7, 2009 | 05:00 PM
Skaterbasist's Avatar
Retired SuperMod
The TSB for excessive oil consumption was for the REVUP engine.
...BUT, the VQ itself consumes quite a bit of oil compared to many other engines out there. It's just the nature of this engine.
Old May 7, 2009 | 10:30 PM
geronimomoe's Avatar
I know that there have been a number of folks who say that their VQ has burned oil. However, there are folks, including myself who haven't seen any oil consumption. Hopefully I won't either.
FWIW, I have an 08 Sedan X sport with 10K miles and the first 9K miles or so, I used the paddle shifters exclusively to ensure a good break-in. I only commute 9.5 miles each way to work and it's all local roads, 8 traffic lights going to work and 7 lights on the way home so I really varied the engine speed and used the trans. I also have no problem flooring it if I have to.
That said, to say "...the VQ itself consumes quite a bit of oil compared to many other engines out there. It's just the nature of this engine." is a stretch, IMHO.
Old May 8, 2009 | 05:38 PM
The-Dream's Avatar
I went 10,000KM without an oil change (I know stupid) I only lost on quart which isn't much at all.
derres
Aug 28, 2015 03:27 PM
ghost_g35
Aug 7, 2015 10:31 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
lemmy999
Jul 25, 2015 12:13 PM
ClwMike
Jul 23, 2015 12:55 PM
