RPM's climb off throttle
Old May 5, 2009 | 07:38 PM
maomao's Avatar
Something that I've somewhat recently (within the last couple months) noticed about my car is that when I let off the throttle and push the clutch in to shift gears the RPM's climb briefly. They climb maybe 300 to 500 rpm from when I let off the throttle
I'm not sure why this is happening. At first I thought maybe I wasn't getting off the throttle quick enough, but I tested that fact to make sure I am. It seems like it is somehow related to my clutch.
Also I do have a lightweight flywheel idk if that would have anything to do with it.
I appreciate any help, thanks!
Old May 5, 2009 | 08:24 PM
madmike1029's Avatar
disengaging any parasitic drag from the transmission could play a slight roll, also maybe a brief delay in the drive-by-wire response. I notice it as well too. That is my theory atleast.
Old May 6, 2009 | 12:20 PM
maomao's Avatar
hmmm, well at least I know I'm not the only one with the problem now
Old May 8, 2009 | 11:33 AM
joe603's Avatar
Try doing an ECU reset. Unplug the negative battery connection and pump your brakes a few times. (this is the quick easy way...)
I had a similar thing happen to my G after it was at a paint shop for a few days. The reset worked for me.
Old May 18, 2009 | 11:53 PM
maomao's Avatar
I'll give that a try joe603, thanks!
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
