Valve body upgrade. 5at cheapest place to buy it?
Did the install, took about 4 hours or so waiting for fluid to drain and cool off and swapping some bolts and all that stuff, the car seems more downshift happy or maybe its just my imagination but whenever I'm at low speeds and I give it more than 1/4 throttle it downshifts and peels out like mad. The shifts are definitely firmer, instead of a "lag" it feels more like a solid shift like you would feel in a manual car. I havent had a chance to take new vids yet but once I do I'll put them up. Coming to a stop slowly it definitely feels a little clunky right before you stop. If your very gentle with it you'll barely notice any difference but once your on the throttle the shifts are very crisp.
As a note to anyone doing this after I was done it took about 5 1/2 quarts to refill.
As far as actually installing the transgo kit that is not something I think I'd be comfortable with.
[QUOTE=sharif@forged;4215849]Yup...it's happened to us, and its very very frustrating. As a rule of thumb, modify your own personal VB...do not try to buy a previous modded version. There are 3 different VB versions I know of, and they are all very sensitive
So would the transgo be something that i could use in my car??? 06g35 coupe
[QUOTE=echang0501;4707486]
yes. The post you tried to quote meant don't buy a used valve body that has already been upgraded... modify your existing - because there are several versions (may not be compatible).
In s nutshell, yes a Transgo kit will work in your valve body.
