MD 5/16 iso copper installed, performance dropped!!
Old May 29, 2009 | 11:23 AM
t7n7's Avatar
Unhappy MD 5/16 iso copper installed, performance dropped!!
hey guys, i'm starting this thread to get an idea of what you guys think I should do.
I bought my car, drove it around.. yeahhh awesome... then... i bought the sprintbooster , installed it... HELL OF A DIFFERENCE!! like a whole new car... then i had my grounding kit/spacers and BIG performance drop
Right now, i HATE driving the car... honestly... its almost like, the only thing that made a difference was the sprintbooster.. i'm sure the MD spacers have gains but do i need to reset my ecu?
the shop (very reputable here in toronto) didn't reset my ecu by default since customers might have custom tuned ecus and they only do it when requested.
SO MY QUESTION IS...
Do i need to reset the ECU in order to see the changes? I want to first take out the sprintbooster, reset the ecu, then reinstall it so i can see the difference from that. Or should i reset the ecu with everything installed?
please let me know what you guys think i should do.... i will be seriously disappointed if my sprintbooster mod didn't function like it did before.
Old May 29, 2009 | 12:20 PM
BloodlineG's Avatar
what the hell is a sprint booster...
Old May 29, 2009 | 12:21 PM
BloodlineG's Avatar
is that like that turbonator thing hahaha?
Old May 29, 2009 | 12:22 PM
BloodlineG's Avatar
"When you put the pedal to the metal, nothing beats the roaring sound and feeling of instant acceleration!" HELL YA SPRINT BOOSTER!
Old May 29, 2009 | 12:25 PM
Swivel's Avatar
Moderator
That was all very helpful Bloodline.
T7, if it were me, I'd reset the ECU and see if that helps at all. Are you sure your manifold is properly sealed as well?
Old May 29, 2009 | 12:41 PM
BostonG6spd's Avatar
Ok WTF is a sprint booster??
Old May 29, 2009 | 12:44 PM
SxExCx's Avatar
I would check for a vacuum leak form the spacer install, you should notice a positive difference after the install.
Old May 29, 2009 | 12:52 PM
BloodlineG's Avatar
i checked the site. didnt find anything helpful... still dont know what it is/does
Old May 29, 2009 | 04:13 PM
t7n7's Avatar
sorry 4 the delay, been so sad.. didn't even bother to login.. maybe i should have it checked again for any leaks.. thanks guys... and i will be resetting the ecu later on tonight...
sprintbooster is a plug-n-play device that will cause you to have instant shifts in manumode (5AT) as well as superbbbbbbbbbbbbb (ya i used that word lol) throttle response. when you want to do a lane change, its easy as pie... the power is always there... and when you accelerate (in 5at), its amazing.. holds the gears longer... revs up higher .. i can go on but it just makes me sad to talk about it considering all of the above is no longer present after the spacer installation...
thanks guys..
Old May 29, 2009 | 05:46 PM
t7n7's Avatar
rofl....
made an appointment with the carshop, not till next thursday though... gonna see if i can get my performance back after resetting the ECU tonight... going to take out the sprintbooster, reset the ecu and drive it around for a while to let the ecu learn properly before "boostin'" it with the sprintbooster lol...
i'll keep you guys updated...
more sprintbooster info: http://my350z.com/forum/body-interio...tro-offer.html
Old May 30, 2009 | 01:22 AM
t7n7's Avatar
I reset it around 7:30pm... drove it as hard as i could.. but was downtown so couldn't do much with the bad roads... still no improvement.... got on the highway... drove it hard...still no improvement... then went for a meet.. and after about 30miles of total driving.. and 5 hours later.. on my way back at around 12:30ish. my car was begging to go faster... not only the shifting and response times are back.. but when i got on the highway... the car KEPT pulling when i pressed the pedal during the whole time.. no matter what speed i was going.. *sigh*...
THanks guys for your feedback.. looks like my booster has finally kicked in and the ecu has properly learned to work with the spacer...
: : THE END : :
Old Jun 1, 2009 | 10:53 AM
uf20wop's Avatar
lol sprintbooster
Old Jun 1, 2009 | 10:56 AM
04G35NYC's Avatar
reset you're ECu and check for leaks.
Old Jun 3, 2009 | 01:46 PM
Tollboothwilley's Avatar
Sprint Booster huh?? Weird. Apparently they are new to Z1 as well...
Old Jun 4, 2009 | 06:16 PM
eZg's Avatar
eZg
Toltally vacume leak
I rem. during my install getting something doubled over when installing MD spacer. I saw it before I got everthing tightened done. Maybe a gasket between lower and upper phlenum???
Hopefully you didn't ocvertighten the bolts on top and cracked your upper phlenum...pretty common if you didn't use a torque wrench.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
linedr89
Aug 17, 2015 05:11 PM
IkonG35
Aug 10, 2015 09:33 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
