Variable Valve Timing Question
Old Jun 17, 2009 | 07:51 PM
EvanP246's Avatar
Whats up guys. I was wondering if the VQ35 in the pre-revup coupes has VVT. If so does it incorporate lift and is it on the intake cams, exhaust cams or both?
Thanks in advance!
Old Jun 18, 2009 | 06:59 AM
superchargedg's Avatar
Yes on the intake cams only.
Old Jun 18, 2009 | 01:56 PM
EvanP246's Avatar
Thanks! what RPM does it engage?
Old Jun 18, 2009 | 04:05 PM
Sorry as i have no clue.
Old Jun 19, 2009 | 08:26 AM
nsyr's Avatar
IIRC, It is variable to 4k.
Old Jun 19, 2009 | 09:26 AM
DaveB's Avatar
There's some sort of major cam change that occurs around 2800-3000rpms. That's where the power really ramps up in my car.
Old Jun 19, 2009 | 02:29 PM
EvanP246's Avatar
Thanks again guys. When I hit around the 2800-3000 in my car i feel the extra power too but the engine note seems to change up in high rpm from 5000 to redline.
Anyway i wish we could have VVEL on our VQ35s apparently you really get a kick when they switch to high cam.
Old Jun 19, 2009 | 02:56 PM
str8dum1's Avatar
ya its definitely in the 3250 range bc when i log, the AFR always gets funny around there.
Old Jun 19, 2009 | 07:41 PM
rcdash's Avatar
The cams are variable 0-38 degree advance over the entire rpm band and can be reprogrammed via stock ECU reflash or using a standalone cam controller like the Haltech. Lift is fixed based on cam specs.
As I recall, the stock ECU intake cam timing map has 0 degrees advance (full retard) at idle, ramps up to max advance in the midrange and then tapers back towards full retard at redline.
Muski_G
Dec 1, 2023 11:11 AM
ghost_g35
Aug 7, 2015 10:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
KevinnnVo
Jul 28, 2015 06:29 PM
lemmy999
Jul 25, 2015 12:13 PM
