Engine Heating Issue?
Old Jun 26, 2009 | 11:07 PM
gary c's Avatar
Originally Posted by Tollboothwilley
Couple heating questions... distilled water vs tap water...why?
Also, a lower temp thermostat - can that cause any issues? If so, how?
Distilled water contains zero minerals unlike tap water which will eventually plug up your radiator with deposits. A lower temp thermostat will not cause over heating issues, but will open sooner and let your car run cooler for the first few miles. Have you checked your fans to see at what temp the come on? Could be a sensor not letting the fans come on at say 200 deesgrees when it's supposed to. Might not be a bad idea to take your car to a reliable radiator shop, have them check out all the possibilities. Over heating isn't good for your car....any of it....
Gary
Old Jun 29, 2009 | 04:41 AM
Tollboothwilley's Avatar
My fans are both running...just like they should be.
I realize that running the car while its hot is a bad idea. My car hasn't been running HOT, just saw the needle move up 2 notches so I turned off the AC and then I turned it back on when i was going ~40 MPH. No problems since then. I still need to burp the coolant.
Old Jun 29, 2009 | 12:23 PM
nyckid's Avatar
what year is your car? I am still awaiting my fans to come and see if that fixed my overheating issues. Weird how your fans are both functioning properly but you still overheat when the A/C is running while your car is in one spot. What else can it be. I am very curious about your problem too. I hope you pinpoint the problem soon as to what is causing it to do this.
Old Jun 30, 2009 | 04:42 AM
Ya, did it again today. I will check coolant level in the AM.
I know it is not related to the fans. I checked them today and they were both spinning and sucking a lot of air.
Old Jun 30, 2009 | 06:25 PM
nyckid's Avatar
are both your fans spinning on high speed? are they cutting on and off? or constantly running when your a/c is on?
Old Jul 1, 2009 | 12:55 AM
A/C fan is on all the time when AC is engaged. The other fan only kicks in if the temp gets high.
Old Jul 1, 2009 | 12:11 PM
nyckid's Avatar
okay to verify, the A/C fan is the one on the driver's side correct? Because i did a comparison on a friends car and its an 07 coupe, both fans spin high speed constantly when the a/c is on, it doesn't cut on or off.
Old Jul 2, 2009 | 03:46 AM
Yes, AC fan is the drivers side. Passenger side should kick in if the temp gets to a higher level.
Its either that, or both should be on with AC at low level, and fans kick up to high level when its at a HOT temp.
Old Jul 2, 2009 | 03:47 AM
either way, both fans should be on full speed if the temp needle moves AT ALL
Old Jul 5, 2009 | 03:26 AM
nyckid's Avatar
My overheating problem is fixed, it was definitely my fans.
Old Aug 6, 2009 | 01:55 PM
SE2002's Avatar
I have 2003 Sedan G35 and i am still having the overheating problem when my AC is on. This only happens in a stop and go and slow traffic....the air gets warm and my temp starts to rise........because when i am on the freeway it works ok and my AC is still cold.. Pissing me off big time arrrrrrrrrr! The dealership said it could be the radiator itself....cuz i already had a flush done, replaced the thermo and made sure my belts are new. Havn't really notice to see if the ac fan turns on actually....going to check that today.
So my question is???
- Where do i get a good radiator and what parts do i need?
1. Radiator Cooling Fan Assembly
2. Condenser (with receiver dryer) <---what is this??
3. Radiator
Is this all i would need to buy?
Thanks guys for the help.
Old Aug 6, 2009 | 08:21 PM
OCG35's Avatar
tap water (especially here) has a bunch of mineral deposits ("hard water")... you don’t want that crap in your cooling system… pour a glass of water from your faucet and let it sit overnight – typically you will see white sediment at the bottom of glass… I don’t want that in me or my car.
Distilled or a good purified water is recommended (I like reverse osmosis for drinking, but use distilled in radiator)
The 350Z thermostat should not cause problems - I've been using one for years (and in ambient temps that you mentioned)... however, yours may be defective - you could always test it to make sure.
Old Aug 7, 2009 | 12:15 AM
I tested my t-stat before I installed it.
I think it might be the E-fans I'm using with the headers not being heat wrapped or what not. Might not ber pulling enough air. That or there is somehow still air trapped in the system. I've heard that some guys let the system burp for as long as 90 minutes.
3. Radiator
have you looked at your oil? Make sure its not getting coolant in the oil.
I think your problem is from your FANS. You need to replace those.
Old Aug 7, 2009 | 12:24 PM
SE2002's Avatar
Coolant in the oil? Last oil change seemed ok...didn't notice any difference. I havn't checked the AC fan (driver side right?) to see if it kicks in when the AC is on....BUT...what if it does lets say kickin? then what could be the problem??? How do i burp the dame thing again?
Old Aug 7, 2009 | 12:27 PM
  #30
SE2002's Avatar
As per the water issue...i dont use tap water at all. Whats the E-fan?..same as AC fan? Is there any documents showing how to install the fans or radiator here?
