Wife's G35... VDC Off, SLIP, and Service Engine Soon Lights All On!
Old Jun 25, 2009 | 11:11 PM
c35's Avatar
c35
Angry Wife's G35... VDC Off, SLIP, and Service Engine Soon Lights All On!
Hey there,
My wife has a 2002.5 G35 sedan with ~ 122K miles.
When I started up my wife’s car after dinner tonight, these lights came on the dashboard:
• Service Engine Soon
• SLIP
• VDC Off
When I put it in gear and attempted to accelerate, the RPM’s increased by ~ 200 and I moved forward like I was basically coasting with the accelerator mashed to the floor.
I pulled the car over, turned it off, and then went through this same routine 2 more times.
Then on the third attempt… The SLIP and VDC Off lights went off—but the Service Engine Soon light remained on—and the car drove normally all the way home.
Any thoughts?
Thanks,
Clint
Old Jun 26, 2009 | 10:27 AM
RobbieG35's Avatar
Sounds like a bad TPS. You will have to replace the throttlebody. I worked at an Infiniti dealer for 5 years, and we would see several a month.
Old Jun 26, 2009 | 07:55 PM
c35's Avatar
c35
Is it something that can be "cleaned?"
Looking to go the cheapo right... Might be trading in the car soon.
Thanks!
Old Jun 28, 2009 | 04:42 PM
djamps's Avatar
You most likely need a new throttle body. They are around $110-$150 for a re manufactured unit and gasket (+ install if you're not a DYI kind of guy).
Although you'll need to scan for codes (go to pep boys) to be sure what the issue is.
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
igking
Jul 19, 2015 01:12 AM
