Problem with Starting my Car
Old Jul 23, 2009 | 03:51 PM
Kcannonpoker@gm's Avatar
I have a 2003 G35 with maybe 70k Miles. I am having a problem where when I go to turn my car on, I put my foot on the clutch, turn the key and nothing happens. The electronics turn on, but the car makes no attempt to start. I brought it to Infiniti and they said that the Starter was bad, so they replaced it. After I got it back, I had the same problem a week later and brought it back in to get it fixed. They said it was wiring and it was fixed again. Well now a month later I am having the same problem. Any Ideas?
Old Jul 23, 2009 | 03:55 PM
LEON NYC's Avatar
Keep going back to them, I believe you have a 90 day warranty after their work...
Old Jul 23, 2009 | 04:32 PM
superchargedg's Avatar
I would guess its the clutch switch going bad.There is a switch or sensor that engages when the clutch pedal is all the way down to complete the electrical circuit allowing the starter to engage.
Old Nov 9, 2009 | 05:20 PM
ypahuboy's Avatar
was the problem solved?
Old Nov 9, 2009 | 05:23 PM
This was exactly the problem. It was the switch between the computer and the clutch
Old Oct 7, 2010 | 04:32 PM
Bildob's Avatar
i belive i am having this same problem. when i try to start the car everything powers up, but there is nothing happening with the starter. Once i begin to pump the clutch pedal the starter will begin to spin. It takes a while for me to pump the clutch and get it in a position where the starter will work.
Did you get a part number by any chance? i think this will be alot cheaper then the $300+ starter infiniti qouted me!
Old Oct 7, 2010 | 04:47 PM
They didn't give me a part number, but it WAS NOT the starter. they did it for free since they ****ed up
Old Oct 8, 2010 | 01:47 AM
Bildob's Avatar
so they charged you for a starter then put in the clutch switch for free! wow i hope you got some money back because the starter $300+ and the switch is only $18.95 form my local infiniti. I would call that a huge F-UP.
By the way i got in touch with the local dealer and this is the part number they gave me. (253 25 D4000) It is $18.59 for anyone else with this problem.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
realtalk21
Jul 20, 2015 09:07 AM
