Hesitation, RPM Dip on Start up
Old Jul 27, 2009 | 01:04 PM
JuniorBass's Avatar
When i start the car the RPM's will rise to 1.5, drop to 500, then settle back to 1.5. The car feels as if it is going to shut off when the "dip" happens. The car did shut off this weekend, but i was able to restart without a problem.
This hesitation happens the majority of times on start up, but occasionally it will start "normally". I am not sure the first thing to look at. The car is an 03 AT with 79k. I have a new battery and am thinking i should replace the alternator since it is 5.5 yrs old.
Could this possible be a fuel injector problem? Any ideas are welcome
Thanks
Old Jul 27, 2009 | 01:11 PM
KING ROCKS G's Avatar
same problem here...any help appreciated!!
Old Jul 27, 2009 | 02:26 PM
sdnpaul5at's Avatar
I had the same problem, I simply cleaned out my throttle body & did an ecu reset by disconecting the battery. If you havn't already cleaned it, this is most likely the problem. Good luck.
Old Jul 27, 2009 | 04:15 PM
JuniorBass's Avatar
Thank you, after doing a little more research i found threads on the internet about Throttle Body cleaning. I figure i will clean the TB and replace the air filter on wednesday and see if i have solved this.
Old Jul 28, 2009 | 12:07 PM
sliderg35's Avatar
This can also be related to vacuum. Check to make sure you don't have any leaks.
Old Jul 28, 2009 | 12:29 PM
Reality350's Avatar
^+1
To be certain, I would check both intake and exhaust systems for leaks.
It could very well be that either your Intake Filter, MAF or TB needs a cleaning, but unless you have removed/swapped/touched them recently, I would wager on a vacuum leak.
Old Aug 31, 2009 | 10:53 PM
JuniorBass's Avatar
AFter a month i decided to do the cleaning. Car starts like a charm now
Old Sep 1, 2009 | 05:52 AM
saulg35's Avatar
what did you clean specifically?
skippyG
Jan 25, 2016 01:18 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
03sedang35
Aug 29, 2015 07:56 PM
Blakearold
Aug 19, 2015 10:20 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
