My New Rear Diff Oil Cooler INSTALLED!
Best to run filters - always, my install i used a filter before and after the pump, to prevent damage to the pump.
Question on temp was asked, my set-up has complete function, but as many as you know, my car see's more shows than the road. If your car is a daily / track best to install a temp sensor into the pumpkin (simply tap and place a temp probe into the diff - I believe Titan makes a kit and / or you can get one from GTM), so you dont have to turn it on and off by a switch as I do. No temp readings where taken.........
Also, you do not need to run the pump unless you're driving the car hard, normal day to day routine, it's not essential to even turn it on at all.
Just FYI
Correct, Always run an inline filter prior to the pump. That's what I did, and it's super easy to do.
Also, if anyone out there is at all interested in setting up a kit, I can get you all the components you require for under $420
