Hotchkis Problems and Solutions
Old Aug 17, 2004 | 08:53 AM
  #31
cato's Avatar
SouthernComfort Moderator
Re: Hotchkis Problems and Solutions
I have the Stillen bars. They are EXACTLY the same as stock
except for stiffness. They fit perfectly.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Aug 18, 2004 | 05:17 PM
  #32
bzabodyn's Avatar
I have the EVO II and the Hotchkis sways - the only problem I encountered was getting the old swaybar out (I had to remove the last portion of the exhaust on the driver's side) - everything else was fine, but now I have a terrible rattling sound coming from the rear passenger side when I go over rough surfaces/bumps and the front makes a sound sound whenever I hit a bump while turning - can anyone help me out?
2003.5 BS coupe 5AT
Clear Corners, Alum. Pedals, Pro-1 Intake, Helix Test Pipes, UR Pulley, Grounding Kit, CF Engine Cover, GReddy EVO II Exhaust, Kinetix Plenum
Old Aug 18, 2004 | 07:47 PM
  #33
richie's Avatar
damm...now I'm a little worried about the install...
'04 Laser Red 6MT
piaas all around (clearance, reverse, dome, door, and fogs)
AVH-P7500DVD / Basslink
Z tube / K&N / Greddy Evo 2
Side Blinker Mod
Old Aug 18, 2004 | 08:17 PM
  #34
SixFive's Avatar
Tighten the bolts down - like while it's on a rack. I have 0 problems now!
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Ohsixgee35
Sep 16, 2015 04:33 AM
mattdg35
Sep 14, 2015 11:28 AM
Mhacker
Sep 12, 2015 07:35 PM
Jnm07
Sep 5, 2015 01:16 AM
