Electronic Beep Instead of Horn Beep
Old Sep 14, 2006 | 06:32 AM
  #106
KPierson's Avatar
I'm pretty sure there is a link to some videos in this thread somewhere.
The lights flash once when the car is locked, and don't flash at all when unlocked. The module has a low current output to control parking lights but neither Dan nor I hooked it up to test it out. One suggestion Dan gave me was to make the parking light output programmable so it only works when you disarm the car.
Old Sep 14, 2006 | 03:28 PM
  #107
LI-G35Driver's Avatar
This is off topic.. but I have the window roll up module and just got the sunroof module from Daniel but havent even opened it yet .. if both are installed.. when issue the windows roll up command, does the sunroof close as well? It seems they both take the same command...
Thanks,
Chris
Old Sep 14, 2006 | 03:34 PM
  #108
SFLG35's Avatar
FGC President
yes it will
you wont have to push the command twice to get them both to close. we wanted to use the same command specifically for that reason
Old Sep 23, 2006 | 04:26 PM
  #109
Silverbolt's Avatar
Hate horn, want beep.... *BUMP*
Old Sep 25, 2006 | 04:56 PM
  #110
Igor911's Avatar
This would be awesome if it were to work!
Old Sep 26, 2006 | 07:08 PM
  #111
SFLG35's Avatar
FGC President
it works
ill try to get a video of mine here shortly been super busy with school.
Old Sep 26, 2006 | 07:17 PM
  #112
Igor911's Avatar
so all you do is tap the signal from the door unlock/lock?
Old Sep 26, 2006 | 09:21 PM
  #113
KPierson's Avatar
You also need to grab power and ground, obviously. The hardest part is getting the wire for the beeper through the firewall and under the hood.
Old Sep 26, 2006 | 09:29 PM
  #114
Igor911's Avatar
That's not soo hard to do. There is already a hole on the passenger side. If you open the battery cover, there is a big black gromet you can open. Stick a metal hanger through there and it pops out of the passenger floor.
Old Sep 27, 2006 | 12:09 AM
  #115
DHCrocks's Avatar
can you just install it in the door?
Old Sep 27, 2006 | 12:12 PM
  #116
KPierson's Avatar
You technically could, but I think it would actually take longer to install it that way, because you would have to take the door panel off and then put it back on. However, I'm not sure how loud it would be if the beeper was installed in the door. Installed under the hood the beeper can be heard fairly equally from the passenger side to the driver side, with only a slight drop in distance directly behind the vehicle.
The door lock wires originate from the BCM, so all the wiring can be done directly at the BCM in the drivers kick panel.
Old Sep 27, 2006 | 03:47 PM
  #117
SFLG35's Avatar
FGC President
have you worked on my idea yet kevin??
Old Oct 12, 2006 | 08:53 AM
  #118
zpeedray's Avatar
any more news on these mod?
Old Oct 12, 2006 | 08:55 AM
  #119
SFLG35's Avatar
FGC President
here let me go take a video of mine now
instead of sittin around doin nothin
Old Oct 12, 2006 | 09:19 AM
  #120
SFLG35's Avatar
FGC President
alright here we go
now keep in mind that these were taken on my little handheld camera and not on a videocamera. it was also a little windy out side so there is some static. on the distance shots its much louder in person then it is on the camera due to the crappy microphone.
http://www.boostedconcepts.com/video...dule%20004.avi
http://www.boostedconcepts.com/video...dule%20005.avi
http://www.boostedconcepts.com/video...dule%20006.avi
http://www.boostedconcepts.com/video...dule%20007.avi
http://www.boostedconcepts.com/video...dule%20008.avi
http://www.boostedconcepts.com/video...dule%20009.avi
