How to strengthen the block/cylinders?
Old Aug 8, 2004 | 09:51 AM
bullseye's Avatar
I am considering an F/I installation, but I understand our stock blocks are hard-pressed to function well under boost. I know a tiny bit about sleeving and nested sleeving. What other methods are available to tie together our open decks to make them stronger? I also contemplate adding forged pistons and rods, not to mention an upgraded tranny valve body. I guess while the head's off, I should consider new cams, valves & springs, and retainers as well. Your thoughts?
'03 G35s 5AT, Garnet Fire/Willow
Staggered 18" SSR GT1/Bridgestone PP S03
Eibach Springs/Sways, Stillen 2-pc BBK
Stillen Intake & SS Cat-Back Dual Exhaust
Old Aug 8, 2004 | 11:30 AM
Q45tech's Avatar
Re: How to strengthen the block/cylinders?
In order to increase HP [reduce friction losses] they used lighter rings with less tension, lighter pistons, lighter rods and a much lighter crankshaft and narrower bearing all around.
It is not just the cylinder sleeves. The previous versions [3.0 liters] were bullet proof from a block stand point] and lasted way too long. How many new car buyers care if an engine can last 300,000 miles +............when does diminished life affect resale value?
Old Aug 8, 2004 | 05:52 PM
Rspec's Avatar
now If I just get the pistons and the rods without sleeving the block, will our stock block can handle..hmmm let say, 500HP??
S-tuned~
Old Aug 8, 2004 | 06:35 PM
bullseye's Avatar
From what I've read, our open decks leave the cylinders unsupported/braced on the open end. Under heavy boost, the cylinders oscillate... kinda like six wiggling fingers. Over time, the cylinder walls may work-harden and crack open like dragon eggs. I'm trying to figure out how to tie the cylinders together so they can handle boost without all the oscillation.
Old Aug 8, 2004 | 11:01 PM
KPierson's Avatar
There's a group buy on my350z.com right now for Pauter rods and Aries pistons... it ends soon and is a pretty good deal, mine our already paid for!
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Aug 10, 2004 | 04:47 PM
636Racer's Avatar
cryo or metalax
| Hawaii International Race School | Formula Hawaii | Drift Session | Mid Pac Road Racing Association |
Kim@Forged
Engine - Power Adders
Feb 22, 2012 12:11 PM
Jim@Showstoppers
Suspension-Vendor
26
Aug 21, 2008 02:54 AM
Crashtest77
Forced Induction
11
Mar 14, 2007 09:10 AM
