Z-TUBE sound
Old Aug 12, 2004 | 03:19 PM
Airs414's Avatar
Z-TUBE sound
So i just put in the z-tube and k&n filter today in my garage and after i installed them i wanted to hear the difference in sound. So while in my garage i reved the engine and around 2500-3000 rpm i hear a small whistle noise. Im just wondering if that is normal for z-tube and k&n filter.
Jump and the net will appear
04 5at coupe
t. blue
premium
performance w&t
splash guards
alum. pedals
on the way:
z-tube, k&n filter, clear corners,
Old Aug 12, 2004 | 03:22 PM
cato's Avatar
SouthernComfort Moderator
Re: Z-TUBE sound
No whistle from mine. Did you forget to attach the crankcase
tube?
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Aug 12, 2004 | 03:25 PM
Airs414's Avatar
Re: Z-TUBE sound
no, i reconnected that first thing.
04 5at coupe
t. blue
premium
performance w&t
splash guards
alum. pedals
on the way:
Old Aug 12, 2004 | 03:55 PM
mamboking's Avatar
Re: Z-TUBE sound
The wistle sound is mostly associated with other CAI or the popcharger.
2004 G35 Coupe/OB/Graphite interior/Premium and aero package/Popcharger/Z tube/Hotchkis sways/Tein H-tech springs/Kinetix plenum/Crawford cats
Old Aug 12, 2004 | 05:12 PM
Airs414's Avatar
Re: Z-TUBE sound
yeah, i turned my car off after reving it the first time checked under the hood and everything was connected and ok. so i pulled on the tube lightly to see if maybe something wasnt tight enough. everything was. so i started my car up again and there is no whistle sound now so everything is good, but i am gonna watch it for a couple days to make sure.
04 5at coupe
t. blue
premium
performance w&t
splash guards
alum. pedals
on the way:
Old Aug 12, 2004 | 08:03 PM
R2 V35's Avatar
Re: Z-TUBE sound
Whistling sound is coming from the K& N filter...
"Is simplicity best or simply the easiest"
Old Aug 12, 2004 | 08:26 PM
roneski's Avatar
Devil's Advocate
Re: Z-TUBE sound
I got a whistle with the K&N, but I usually can only hear it in lower RPMs at WOT, though I guess in a garage it could be more obvious because of the enclosed space.
Ivory Coupe 5AT
Z tube, K&N drop in.
Crawford Plenum and Fujitsubo Exhaust soon to come...
Old Aug 12, 2004 | 10:00 PM
Airs414's Avatar
Re: Z-TUBE sound
thanks a lot, that definitly makes me feel relieved that nothing is wrong.
04 5at coupe
t. blue, premium
performance w&t, splash guards
z-tube, k&n filter, clear corners, alum. pedals
Old Aug 17, 2004 | 03:53 PM
jdbinspired's Avatar
Re: Z-TUBE sound
I installed my z-tube and pop-charger last night… Noticed a little difference in sound and in response in throttle… Sound wise… Not to impressed. Still to quite for me… Need to install some exhaust.
< aRTiFiCiaL iNTeLLiGeNCe iS nO MaTcH fOr NaTuRaL sTupiDiTy >
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
