Service Engine Soon: P1148 & P1168
Old Dec 4, 2009 | 05:47 PM
heftylefty58's Avatar
Question Service Engine Soon: P1148 & P1168
My Service Engine Soon light came on 2 days ago, and my 2004.5 G35 Sedan currently has ~47k miles on it. Two weeks ago, I did change the oil & rotated my tires, but I can't think of anything else that was recently done to the vehicle. The only mod I have is the MD 5/16 plenum spacer which I installed about 1.5 years ago.
This afternoon, I took the G35 to my local parts shop to scan my car. They actually found 2 codes:
P1148 Closed Loop, Bank 1
P1168 Closed Loop, Bank 2
They think this means that 2 of my 4 oxygen sensors need to be replaced, but couldn't tell which 2. Has anyone gotten these codes before? Any idea what I can expect to pay in parts and labor? Any idea what usually causes o2 sensors to fail?
About 10 mins ago, I went ahead and [successfully] cleared my CEL after checking out Msedanman's Easy Ecu Resetting thread. Was that a bad idea? Is it safe to continue driving around like this, or should I bite the bullet and get to the dealership right away?
Any feedback is greatly appreciated.
Old Dec 4, 2009 | 06:03 PM
Tollboothwilley's Avatar
Closed loop is defined based off throttle position and the runs off of the O2 sensors on the exhaust manifolds.
The post-cat O2 sensors are strictly for emission purposes.
It sounds like you need to replace both of your O2 sensors UPSTREAM - on the headers/exhaust manifolds.
Resetting the ECU will not get rid of the problem and the CEL will return if the sensors do need to be replaced.
Old Dec 4, 2009 | 06:19 PM
Thanks Tollboothwilley. I searched rockauto for upstream oxygen sensors, but couldn't tell which ones to order:
  • BOSCH Part # 15730 {OE SmartLink - Universal Fit}
    Upstream; 2WD; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles
    $48.79
  • STANDARD MOTOR PRODUCTS Part # SG1405
    Upstream Sensor; RWD; 2 Required per Vehicle
    $102.99
  • BOSCH Part # 15524 {OE Type - Exact Fit}
    $124.79
Any recommendations?
Old Dec 4, 2009 | 06:24 PM
Well, personally I just cut the wires and wire in a universal one. $60 vs $164 (local parts store cost). Makes sense. Some people don't mind paying the extra for the direct OEM fit...so it can clip right in. Its your call.
BTW, $48 for that seems like a great price.
Old Dec 4, 2009 | 06:42 PM
I might actually buy 2 of those...i need to replace the sensors on the headers...I've got 150K miles on them.
Old Mar 27, 2012 | 01:12 AM
Just a quick update: Since resetting my ECU over 2 years ago (ie, back on 12-04-2009), the CEL hasn't returned. Thanks g35driver for being such a fantastic resource!
Old Nov 3, 2017 | 11:26 PM
Foxtrot_01's Avatar
Hello, I have a 2004 G35 6MT with 122k miles, two weeks ago the service engine light went on and it's been on since. I bought a bafx reader and got the P1148 fault code.what is the right procedure, take it to the dealer or a mechanic? How bad is this?
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
poker_lamina
Sep 1, 2015 09:04 AM
03sedang35
Aug 29, 2015 07:56 PM
Ivan Duben
Canada
Aug 29, 2015 12:50 AM
igking
Jul 19, 2015 01:12 AM
