Hard-wired Radar?
Old Aug 27, 2004 | 04:23 AM
snboarder84's Avatar
Hard-wired Radar?
Has anyone hard-wired their radar detector? I have a passport 8500 x50 and am wondering if anyone has it wired. If so, any pics and/or suggestions? Difficulty? Thanx
Old Aug 27, 2004 | 12:11 PM
Gordgee's Avatar
Administrator
Re: Hard-wired Radar?
From the FAQ section:
Passport Hardwire
Lots of info for mods, etc. on the FAQ: and adviseable for all Newbies to check out.[img]/w3timages/icons/smile.gif[/img]
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Aug 27, 2004 | 02:08 PM
thanks you very much. by any chance, does someone have the photos that were posted on that site? they are no longer available
Old Sep 18, 2004 | 05:43 PM
ZeroGen's Avatar
Omega Enthusiast
Anybody know how they wired the ground wire from the radar detector? I have a V1 and am trying to to figure out how to ground the black wire from the direct power adapter without having to drill into sheet metal. Also, I'm going to tap into the center light console. Any pics would be helpful.
Old Sep 18, 2004 | 07:39 PM
xswl0931's Avatar
I tapped power from the driver's side lighter socket. There's a screw attached to a metal bracket nearby. I grounded on that. Works great.
Old Sep 20, 2004 | 08:48 AM
Meatshackle's Avatar
Deep Sea Moderator
Our cars have screws drilled into the metal from front to back. You can look behind any interior panel and see grounding screws. You shouldn't have to drill into your car for any small grounding jobs.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Old Sep 20, 2004 | 10:38 PM
ZeroGen's Avatar
Omega Enthusiast
Russ, thanks. I'll try looking for a grounding screw. When I took off the center lighting console where the sun roof switch is at, I didn't find any grounding screws. Did you hard wire through the center console? If you did, is there a grounding screw nearby?
Old Sep 22, 2004 | 11:25 AM
G35PhatS4's Avatar
G SQUAD
I believe this is EXACTLY what you're looking for. Speedaholic wrote a great DIY with PIX on how to hardwire the Escort 8500 x50. Just get the accessories for hardwiring for ~$30...
http://www.imagestation.com/album/?id=4288850807
6MT DG Coupe | Prem | NAV | Aero | XM | Z-tube | Clears | 40%Huper | RH J5 Pro 19"
Old Sep 23, 2004 | 11:13 PM
ZeroGen's Avatar
Omega Enthusiast
Cool, thanks. This definitely helps.
suby01
Not G35 Related
May 25, 2016 03:07 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
MrElussive
Oct 16, 2003 11:21 AM
Colonel
May 5, 2003 01:17 PM
