Heat shield rubber for JWT Pop?
Old Aug 28, 2004 | 06:28 PM
nsanbyker's Avatar
Does anyone know how to make the heat-shield rubber and stock intake(center plastic piece) fit together better?
nsanbyker
DIY Pro
Old Aug 28, 2004 | 07:35 PM
Kyosho's Avatar
Re: Heat shield rubber for JWT Pop?
theres not much you can do here. you can shrink the diameter of the tube by pulling the two rubber ends closer (so they somewhat overlap) but at a loss of air flow. or you can just have both openings face toward the front so that heated air from the engine is blocked. either way you wont be noticing much of a difference, as long as a majority of it is sealed you should be fine. some people even run their popchargers without the heatshield, but i remember that setup putting out less rwhp on dynos than the ones with the heatshield installed.
Old Aug 28, 2004 | 10:58 PM
nsanbyker's Avatar
thanks for the info
nsanbyker
DIY Pro
Old Aug 29, 2004 | 09:41 AM
DED's Avatar
DED
I stretched it out as far as I could and used zipties to hold it in place.
2004 G35C 6MT Black. Killer.
Old Aug 30, 2004 | 12:11 PM
nsanbyker's Avatar
thanks for the info and image, DED
nsanbyker
DIY Pro
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
