Put on stillen airbox today
Old Aug 28, 2004 | 07:40 PM
nismo4090's Avatar
1 word of advice beware of the o ring, i have never had so much trouble with such a little piece of metal in my life
Back in Black
Old Aug 28, 2004 | 09:42 PM
PiMpG35's Avatar
Re: Put on stillen airbox today
HAHA OMG!! i had the same problem.. it's a pain
2003 G35 5AT
Clear Corners
Navi/Sport/Aero
Stillen Hi-Flow Airbox
Old Aug 29, 2004 | 01:07 AM
nismo4090's Avatar
I thought about it afterwards wtf is the point of that piece anyways? Wont it work without it?
Back in Black
Old Aug 29, 2004 | 02:14 AM
PiMpG35's Avatar
do you have the z-tube also??
2003 G35 5AT
Clear Corners
Navi/Sport/Aero
Old Aug 29, 2004 | 02:28 AM
PiMpG35's Avatar
Also does yours make a whining noise?
2003 G35 5AT
Clear Corners
Navi/Sport/Aero
Old Aug 29, 2004 | 11:44 AM
nismo4090's Avatar
I have a z tube and it sorta makes a whine
Back in Black
Old Aug 29, 2004 | 07:59 PM
PiMpG35's Avatar
k just making sure
Old Aug 29, 2004 | 09:42 PM
nismo4090's Avatar
yea i wasnt sure if that was how it was supposed to be. Do you know what im talking about with the o-ring, looking back on it it seems like it was a needless step
Back in Black
Old Aug 31, 2004 | 07:44 AM
cato's Avatar
SouthernComfort Moderator
Not sure what you are referring to. O-ring on Stillen box?
I bought mine mid 2003 and don't remember a metal O-ring.
There was a rubber ring between the MAF tube and the back
of the Stillen box.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Aug 31, 2004 | 02:26 PM
GPorsch's Avatar
If you mean the large "venturi ring" or 'velocity stack' made of aluminum. Bolts to MAS and the filter clamps on to it. It helps to smooth out air flow coming in. It acctually makes a good difference to have it. It is a good design.
Congratulations! You have just won 1 million punches in the face!
Old Aug 31, 2004 | 03:23 PM
cato's Avatar
If you are talking about the "venturi ring", yeah, I had a bit of a
problem. Finally I decided that Stillen didn't make the holes
big enough, so I drilled them out a tad larger. No problem
since. I have removed the HFAB to clean the filter once. No
problems putting it all back togeather again.
Old Aug 31, 2004 | 08:32 PM
nismo4090's Avatar
no im refering to the o ring on the old airbox that is riveted in and the directions say to remove it. If I could find the directions I could explain better
Back in Black
Old Sep 2, 2004 | 11:26 AM
cato's Avatar
I don't remember any O-ring on the stock air box! Where is it
located. Now I'm worried. What are you supposed to do with
it?
Old Sep 2, 2004 | 12:14 PM
z_with_back_seat's Avatar
Keep the rivited o-ring on your stock airbox. It is not needed to set-up the Stillen box. The instructions are a little confusing. After I drilled out the 4 rivets I realized I did not need it.
What they are referring to is the billet ring included with the kit. Just attach the MAF, New Stillen Box and the Billet Ring included with the kit together. That is the way it is supposed to fit together.
If you are also putting on the Z-tube the large vacuum line is now on the bottom of the intake tube. Do not worry about the hose not fitting. It does, just do not forget to attach it.
The other trick I figured out the hard way was the bottom bolt in the new box. Peel back your wheel well liner on that side and you will be able to reach that bolt really easy. Much better than trying to do it blind reaching around the filter.
I would suggest resetting the ECU after you are done with it. It will help to relearn what the car has on it.
Enjoy and do not freak out if you hear a whistle sound around 3-4k rpms. That is the sound the intake makes.
Hope all that helps,
Terry
G35C - 6MT, DG/G, Aero, BSM, Flaps, Stillen Intake, Z tube, Crawford v5, 6 Wire Grounding Kit, Clear Corners, 2nd Battery (Brake) Cover, Sirius, Momo F16 Evo Shifter, 30% 3M Tint & more to go
Old Sep 3, 2004 | 12:27 PM
nismo4090's Avatar
yea i managed to use the o ring that came with the old box on the stillen high flow airbox. I have it so the airbox maf connects to the new airbox that connects to the o ring that connects to the filter. I probably should just take out the old o ring but thats the idea that I got from the directions.
Back in Black
Spartan268
Aug 20, 2015 09:14 PM
linedr89
Aug 17, 2015 05:11 PM
Team STILLEN
Aug 10, 2015 08:17 PM
Jussaku
Aug 4, 2015 12:45 PM
Jadenkid22
Jul 14, 2015 12:33 AM
