Y-Pipe / X-Pipe / H-Pipe / Dual-Pipe
Old Feb 23, 2010 | 09:52 PM
Bnag0's Avatar
Can someone shed some light on the main differences between these or just let me know of a good thread to review... Thanks!
Old Feb 25, 2010 | 10:47 AM
thelarsky's Avatar
Originally Posted by http://en.wikipedia.org/wiki/Aftermarket_exhaust_parts#Mid-pipe
The section of tubing between the catalytic converter(s) and the rear muffler on cars that have two parallel exhaust pipes. Performance mid-pipes often have a perpendicular connecting pipe or the pipes temporarily merge. This is to equalize the pressure in both exhaust pipes and keep the engine back-pressure as low as possible since back-pressure is detrimental to high end power.
* H-Style Pipe where there is a perpendicular connecting pipe, resembling the letter H
* X-Style Pipe or X-Pipe where the exhaust pipes temporarily merge, resembling the letter X
Y-pipe is just there to merge 2 down pipes into 1 outlet, as in the the letter Y. 1st gen sedans need this because there is only 1 mid-pipe/muffler.
Dual pipe - not sure what you mean by this, but I suppose it is possible for a car to run 2 pipes that never merge. I don't think you'd want to for the reason given above. Dual pipe could also mean a true dual exhaust with X or H pipe and 2 mufflers.
You might get better response if you shed some light on the context of your question - what are you looking to do?
Danielek
May 1, 2022 01:28 PM
Video Share
Jan 31, 2017 04:00 PM
Moskvitch
Sep 14, 2015 10:15 AM
kevintandmd
Sep 3, 2015 06:41 PM
