Got my new toys.... (well, some of them)
Old Sep 9, 2004 | 07:29 AM
zimbo's Avatar
Re: Got my new toys.... (well, some of them)
I'm having a really hard time believing that it will take 18psi on a built motor to reach 500rwhp.
--Steve
Old Sep 9, 2004 | 11:42 AM
Hydrazine's Avatar
Right ON! Good to see you are dialing in your system like an obsessive compulsive engineer! It's the only real way to mod a G! =D
In Theory, practice and theory are the same.
In Practice, practice and theory are not the same.
2004 G35 6MT Blk/Blk Sedan Stillen Air, Stillen Exhaust
Old Sep 9, 2004 | 12:00 PM
GurgenPB's Avatar
Steve
It will probably take around 1 bar to reach 500 pretty easy (on this compression), 18psi WILL imo get you over 550 and near 600. I think I am being pretty conservative with the numbers here, given that my compression ratio is on the aggressive side.
G
Old Sep 9, 2004 | 12:06 PM
GurgenPB's Avatar
Thnaks DesiG
I sure hope so
Old Sep 9, 2004 | 08:48 PM
Rob_G35's Avatar
In Search of Magic
Man Gurgen why do you have to make me jealous. J/K I hope everything works out.
03 CB Coupe 6MT
Old Sep 9, 2004 | 09:38 PM
booger's Avatar
Gurgen....Did you have a lsd and swap it out for a VLSD ? Or did you have a open rear end and changed it out for a VLSD ? I got an open rear end , AT5. And Im wondering what it takes to go to VLSD and 3.5 ring and pinion from a MT6
Couldnt afford it when young...gonna play when Im old
Old Sep 10, 2004 | 02:28 AM
GurgenPB's Avatar
I swapped out the entire mushroom from a 350z, the whole diff. I had an open diff before
Old Sep 10, 2004 | 05:08 AM
zimbo's Avatar
It's a pumpkin, not a mushroom
--Steve
Old Sep 10, 2004 | 09:17 AM
3point5SE_Auto's Avatar
depends on what he ate the night before. good luck dude. don't neglect that tranny. cooling, cooling, cooling, higher line pressure (i.e. shift kit you need a VERY aggressive kit). I feel for that tranny however. do you have a finned differential cover yet? they make em, you need one, buy it now. the diff is going to be generating a lot of heat as well
with the premium package you have a/c going to the rear of the center console. perhaps you could cut one and send the air into the tranny hump underneath the car to remove some more heat?
you are going to need some seriously innovative ideas to keep that tranny cool at that power level.
I give your tranny 1.5 to two years at the most even with a "bulletproof" level 10 tranny rebuild.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
Old Sep 11, 2004 | 07:51 PM
CKwik's Avatar
Anyone know what the stock block will handle? Being open deck, I'm a bit concerened but I haven't seen any data or experiences anyone has had with this. Are you doing anything to address it. The only solution I've seen so far is teh Stroker/Sleeve kit from AEBS, but it should be possible to beef it up plenty with a block guard like the Honda guys use. Though I'm not sure if that is available for the VQ either.
Old Sep 13, 2004 | 12:12 AM
SteveAreno's Avatar
Just throw in a greddy T78 and run 30lbs. Or better yet a T88 and run 40lbs. Veilside did it, no big deal right?
SCZ on my350z.com
2004 G35 Coupe 6MT | OB/Black
Premium | Aero | Splash Guards | XM
Z Tube | Pop Charger
Helix Test Pipes
Unorthodox Crank Pulley
Injen SES
USCG35
Apr 15, 2013 08:41 PM
