My car is leaking something, any idea what?
Old Mar 25, 2010 | 10:47 AM
  #31
Tollboothwilley's Avatar
You only need to worry about the locations the oil is getting out. If its just the oil pan then :
drain the oil
pull off the pan (you'll have to cut the RTV seal)
scrape/remove old RTV
clean area well
Apply RTV
reinstall oil pan (torque bolts to proper spec)
add new oil
should change filter while you're at it.
Old Mar 25, 2010 | 11:18 AM
  #32
Mr_pharmD's Avatar
Originally Posted by cpufreak3
My car seems to slowly be leaking something. I thinks it's the oil, but I don't see a leak near the drain plug or oil filter.
Anyone know any other places it could leak? How about other fluids?
If it helps, the substance is all over the center jack point under the front of the car.
it's a sad moment for men everywhere when one of us cant tell if the fluid is oil or not.
Old Mar 25, 2010 | 01:03 PM
  #33
Blue Dream's Avatar
I drove ttrank's car solo
drain the oil
pull off the pan
clean area well
Apply RTV
add new oil
Only thing I would add is follow the directions on the RTV. Hand tighten the bolts, let the gasket cure for 8-10 hours, tighten to proper torque specs, and then add the oil.
Old Mar 25, 2010 | 03:03 PM
  #34
cpufreak3's Avatar
Is there any reason why I can't use this: http://cpwstore.carpartswholesale.co...location=Lower
Seems easier than a liquid gasket...
Old Mar 25, 2010 | 03:36 PM
  #35
I'm sure you could use it. Or you could get a oil pan spacer and just increase oil capacity while you have the oil pan off
Old Mar 29, 2010 | 04:41 PM
  #36
cpufreak3's Avatar
Ugh, I'm having doubts about the oil pan gasket.
I checked under the car today and there was a bead of oil on the silver part the oil filter connects to (oil cooler I think).
The top half is perfectly clean. If the oil pan gasket were bad, I don't think oil could jump over to there... but at the same time, could the oil from the cooler show up at other random areas (the plastic cover under the car is a mess)
Old Mar 29, 2010 | 08:02 PM
  #37
Blue Dream's Avatar
The oil cooler has a gasket (O ring) on the backside away from the filter. It's possible this has gone bad and needs to be replaced. The oil will drip and be spread on other parts if this is leaking. My car had this issue when I bought it and it was fixed for free under the powertrain warranty.
Other than that
Old Mar 29, 2010 | 11:14 PM
  #38
cpufreak3's Avatar
I'm out of warranty, but I think that's the problem.
I even saw another thread where the user said he had his oil pan gasket replaced, but the oil cooler seal was what went bad and made it look like the oil pan gasket was causing the problem.
Old Apr 21, 2010 | 01:20 AM
  #39
cpufreak3's Avatar
RESOLVED: Oil Cooler gasket has been replaced, no more oil leak
Old Apr 21, 2010 | 06:10 AM
  #40
Blue Dream's Avatar
Just what I suspected. Glad you found th issue and got it fixed.
chinee
Jun 10, 2024 07:48 PM
slider_ua
Jul 29, 2015 04:17 PM
will091195
Jul 27, 2015 09:19 PM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
