HELP!! LOW TIRE PRESSURE GAUGE WONT GO OFF
Old Sep 10, 2004 | 01:05 PM
rooki's Avatar
had a flat tire, donut was used, less than 12 hours later it was replaced with full size tire. now the low tire pressure gauge stays on continously, how do i turn it off
Old Sep 10, 2004 | 05:30 PM
roneski's Avatar
Devil's Advocate
Re: HELP!! LOW TIRE PRESSURE GAUGE WONT GO OFF
Check the pressure of all of your tires and be sure that they are abouve 35 psi. Then you should just have to go and drive it above 40 mph and it should go off.
Who fixed your tire BTW? Are you sure that they didn't remove or break the sensor?
Ivory Coupe 5AT
Z tube, K&N drop in.
Fujitsubo Catback
Old Sep 10, 2004 | 09:03 PM
Aznteazer's Avatar
i wish our cars had the pressure monitor like the 350z ones where they actually show the # of the pressure the tires are in.
Old Sep 10, 2004 | 09:06 PM
Aznteazer's Avatar
like this one
Old Sep 10, 2004 | 09:35 PM
JKDman's Avatar
Dood, the tech that changed your tires either forgot to reset the Tire Pressure Monitor.
I had a rim changed out on my G and for a while, the warning came on. Someone mentioned that in the Owner's manny, the warning coming on without an audible signal means it needs a little tweeking and does not mean that you're pressure is low.
Go to the dealer, tell them what the issue is. Ask them to reset the Tire Pressure Monitor. That *SHOULD* be all there is to it.
GL HF
| 2004 G35 Coupe 6MT | Diamond Graphite/Graphite | Premium Pkg | Aero Pkg | Navigation | SKYLINE+GT350 emblems | Clear Corners | 35% & 50% Tints |
Old Sep 11, 2004 | 03:52 AM
eldy's Avatar
You might want to try this... inflate your tires to 40 psi (18" wheels) and see if the TPM light turns off. It should turn off after about one minute after you re-start your car. Once it is off, lower the pressure to 35 psi cold.
Old Sep 11, 2004 | 11:34 PM
GGGGGGGG's Avatar
I assume your tire pressure light was already on when you got the flat not after tire replacement, right? If that's the case, you need to replace the sensor as well before service ppl can reset the light.
Old Sep 12, 2004 | 12:09 AM
cynicaL102's Avatar
just bring it to the dealer and have them reset the tire pressure monitor.
[ 2004 G35 coupe ] - | 6MT | Black/Graphite | Premium |
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
TWASkyliner
Aug 1, 2015 11:43 AM
joedaddy1
Jul 28, 2015 02:58 PM
