PULLEY UPDATE miles/problems?
Old Sep 15, 2004 | 02:57 PM
nuttyprof's Avatar
ok guys, this is an update thread:
for those of you guys with aftermarket pulleys, please answer a couple of questions to help out the community:
1. how many miles have you the pulleys on your car?
2a. have you had any problems?
2b. if so, what problems?
3. are you happy with them?
G35s6mt/TSecu/350Z Springs&Struts/K&Nfilter+Z-tube/StillenDualExhaust /6WireGroundKit/KinetixHighFlow
Old Sep 15, 2004 | 04:31 PM
al503's Avatar
Re: PULLEY UPDATE miles/problems?
~11K miles
No problems
absolutely
Old Sep 15, 2004 | 06:01 PM
BrianlG35C's Avatar
Ohio G Club Member
10K miles
No Problems
Love it!
G35C 6MT/Dynashield/Z-Tube/JWT Pop-Charger/Nismo Exhaust/Ultimate Cats/UR Pulley/ Tein H-Tech Springs & 30% Tint
Old Sep 16, 2004 | 08:14 AM
malx's Avatar
True... but thank God we have "test dummies" that are voluntary... THANKS GUYS!
Thanks - Joey Avino
Old Sep 16, 2004 | 08:25 AM
SixFive's Avatar
7-8k miles no problems - love the extra punch
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Sep 16, 2004 | 08:58 AM
ddmander's Avatar
I've had my UR crank pulley on for about 6K miles and am loving it! No problems, the extra power is great.
'03.5 G35 Sedan Premium, Aero & Sport Packages w/Auto
Desert Platinum w/wood dash & cabin trim
Injen CAI, Borla catback exhaust, Tein H-tech lowering springs, UR crank pulley, Technosquare ECU, Nismo sways<P ID="edit"><FONT class="small"><EM>Edited by ddmander on 09/16/04 05:59 AM.</EM></FONT></P>
Old Sep 16, 2004 | 12:02 PM
malx's Avatar
What was the issues with these pullyes? No damper correct so the engine vibrates more?
Thanks - Joey Avino
Old Sep 16, 2004 | 12:08 PM
SixFive's Avatar
If you go to maxima.org or whatever maxima site is good - you'll see that this is a non issue more so than any other mod. hundreds of thousands of miles and no issues. The engine is internally balanced and no one seems to be able to sense add'l vibrations from the belts which wont have the rubber dampner on the crank if the stock crank pulley is replaced.
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Sep 16, 2004 | 01:23 PM
ddmander's Avatar
As I indicated in my post reply, there are/were NO ISSUES. The crank pulley is a piece machined from high-strength aluminum, having much greater inherent balance than the cast iron piece that it replaced. I don't know what your reference to "damper" is.
Old Sep 16, 2004 | 01:42 PM
malx's Avatar
Yeah actually neither do I. So there are no issues... cool [img]/w3timages/icons/smile.gif[/img] maybe I'll get them. What was the HP increase on the 6MT coupe? 5HP?
Thanks - Joey Avino
Old Sep 16, 2004 | 02:06 PM
SixFive's Avatar
I'm repsonding to Malx. And you are correct - no issues - I would bet there is measurable less vibration so based on hogwash I hear - the naysayers would be better off with the billet cut pulley rather than the stock one!
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Sep 16, 2004 | 03:12 PM
nuttyprof's Avatar
the only issues were the claims of the "experts." but their arguments were so strong at the time that it changed the views of many a potential pulley modder.
that extra power is so damn addictive though. its not really a hp gain, but more of a faster rev, better drivetrain gain, such as changing your flywheel.
Old Sep 16, 2004 | 03:22 PM
SixFive's Avatar
"It is due to the torsional excitation of the crank with each piston power pulse. The theory is the torsional stresses applied to the crank causes fatigue over time and can cause a failure. Some manufacturers put harmonic dampers and balancers in the crank pulley to reduce the torsional stresses thereby increasing the fatigue life of the crank. Some engine's have them some don't. "
this keeps going in circles...someone says the rubber dampner is for belt vibration and then someone says it's for internal vibrations which I think most of us agree that nissan made the engine internally balanced..in fact theres an article i saw somewhere during one of these threads.
Essentially it's illusive the reasons not to have one IMO. It will help if someone would just prove us pulley guys wrong..until then the adamance of the arguer seems to rule reasoning.
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
UR Crank Pulley
