RPM is Rev'ing up high when accelerate
This is recent, when I switch gears and accelerate (step on gas pedal) the rpm jumps up to 3 or sometimes 4 rpm and then comes back down where it is suppose to be. Does anyone know what is causing this problem? I do not want to take it to the dealership because they do not know what is wrong.
Sounds kind of like a slipping clutch. Could you describe a little more? When the RPM's jump does the car accelerate as well or does it shoot up and then the car has to catch up to that RPM?
I got a JWT lightweight clutch and flywheel, and no problems here...and that is exaclty what happened to mine before it went out....good luck....Mine was due to the shift fork pivot bolt breaking....
magnetism80
Feb 1, 2019 10:00 AM
