has anyone ever fix the p1274 & p1283
Old Jun 7, 2010 | 04:51 PM
RHINO04's Avatar
just wondering if anyone fix that problem with the p1274 & p1283 codes popping up.. please help
Old Jun 7, 2010 | 07:59 PM
jamesond19's Avatar
try this
Was there any kind of work done on your car recently? One thing that you can do is do an idle air volume learn on your vehicle. Your vehicle may be out of adjusment thinking that it is rich/lean in the respective sensors. Try that if you can or take to someone that can do the idle learn for you and see if that helps.
Old Jun 7, 2010 | 08:16 PM
RHINO04's Avatar
My car has aftermarket exhaust and headers with an cold air intake.
Old Jun 7, 2010 | 08:20 PM
jamesond19's Avatar
yeah, I would try to do the idle relearn. The aftermarket exhaust and intake are just operating out of the factory specs from when the stock was on the vehicle. Try to relearn it and see if that does the trick.
Old Jun 7, 2010 | 08:24 PM
RHINO04's Avatar
Well what is this about the non foulers/ o2 extenders
Old Jun 7, 2010 | 08:40 PM
jamesond19's Avatar
Sometimes when installing headers and exhaust the air flows to fast for the o2's to pick up the correct signal. That is why they put o2 extenders that trick the bcm to think that the o2's are reading in range when they are not. You would have to do that if th service engine soon light is still on after doin the idle relearn.
Old Jun 7, 2010 | 08:57 PM
RHINO04's Avatar
Did u do this to ur car??
Old Jun 8, 2010 | 02:53 PM
jamesond19's Avatar
I do this on my car about every 3-4 months just for the heck of it. I really watch my gas mileage and want to make sure my vehicle is operating optimally.
Old Jun 8, 2010 | 03:03 PM
RHINO04's Avatar
so the light hasnt came back on for you? are you happy with you car? and have you had any other problems with it? whats you gas mileage?
Old Jun 8, 2010 | 03:41 PM
jamesond19's Avatar
I never had the light on, I work on nissans/infinitis. I get about 19-22 mpg depending on if I am really getting on the gas or not.
Old Jun 8, 2010 | 03:46 PM
RHINO04's Avatar
ok kool thx james..
Old Jul 12, 2010 | 04:57 PM
Nor_CalG35's Avatar
did you get this fixed??
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
NyCrAzY
Oct 1, 2015 09:19 AM
