Greddy catch can install
Old Jun 19, 2010 | 07:03 PM
Andrei's Avatar
This is not the right catch that fits in the middle of the timing cover but I am using it now because the car needs it (oil gets in the upper and lower plenum). I'll use this same catch can later as a coolant overflow tank when I get a second catch can that fits in the middle of the timing cover.
This is the one that fits in the middle of the timing cover:
This is what I have:
This is the proper setup. One catch can is an overflow tank for coolant and one is an oil catch can. Picture courtesy of XKR@G35Driver and my350z running 1000+ whp DJ with an open deck VQ35 stroked to 4L.
Old Jun 19, 2010 | 10:24 PM
jibberjabbers's Avatar
Would this fit with the OEM engine cover on?
Old Jun 19, 2010 | 10:32 PM
Andrei's Avatar
Absolutely not. It can hardly clear the VTC cover and the hood.
Old Oct 13, 2010 | 02:49 AM
Andrei's Avatar
UPDATE
The catch can has been catching about 4-6 fl.oz of oil every 2 months or so. Today I will remove the upper and lower plenum for another project and will look for any oil that might have gone in since replacing the valve covers.
Old Oct 14, 2010 | 01:27 AM
Andrei's Avatar
I took it apart and did not find anymore oil puddles. Just some oil vapor here and there.
Old Oct 14, 2010 | 05:34 AM
Blue Dream's Avatar
I drove ttrank's car solo
Looks like it's doing it's job.
Old Nov 5, 2010 | 02:15 AM
Andrei's Avatar
UPDATE
This piece of **** catch can caused a vacuum leak on my car, not leaking anymore right now. Turns out the oil level reading plastic pieces were loose. Leak sounded like a hissing noise which I thought was normal.
Today I will go find NTP plugs to get rid of that and plug the holes.
Old Nov 5, 2010 | 02:52 PM
Andrei's Avatar
This is how I fixed it. I also changed the Greddy hoses out because they got dried up and got brittle.
Old Nov 9, 2010 | 03:02 PM
Andrei's Avatar
I have another update.
I router the driver side valve cover to the catch can. I could still smell oil and gas vapor and this will fix that problem.
Old Nov 10, 2010 | 12:59 PM
Andrei's Avatar
That setup did not work and caused a vacuum leak. I just caught on to it today because it was a very small leak and the RPM was still somewhat steady dropping and raising only slightly but at very long intervals.
The driver side valve cover is venting under the car now.
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
RA102223
Aug 15, 2015 09:24 PM
ghost_g35
Aug 7, 2015 10:31 AM
lemmy999
Jul 25, 2015 12:13 PM
