Burning oil, need suggestion on new viscosity!
Old Aug 31, 2010 | 04:05 AM
caketech's Avatar
Hi guys
i have a 04 coupe with 75k KM so i'm guessing around 48k miles?
anywho it's always burned oil and lately it's burning more than usual
i've been using Mobil 5w30 since i bought the car about 20k ago. i'm planning on switching to Castrol to try and see if it's any better, as I've read on this board that it's a bit better.
what do you guys think? 10w30 or 10w40? or should i stick with a 5?
thanks guys
Old Aug 31, 2010 | 12:59 PM
305G35's Avatar
go synthetic. mobil one ftw! i've used it since i drove off the lot. the rule of thumb is as the egine ages you go up in weight. there is a tech spec around the web. google it.
Old Aug 31, 2010 | 09:21 PM
caketech's Avatar
^ yea i've been using mobil 1 synthetic.
still burns probably 2 L every 3.5k miles.
i'm thinking of just switching to 10w30 and calling it a day.
Old Aug 31, 2010 | 09:52 PM
dukehotty's Avatar
If you car is burning excessive oil, you should take it in and see if it falls under the Infiniti recall. It could get you a new engine! Do a search on this forum. I think it is only for manual transmission G35's.
Old Aug 31, 2010 | 10:02 PM
WhosRich's Avatar
Even if he's auto, if he's consuming that much oil, he'll be covered.
Old Aug 31, 2010 | 10:03 PM
dukehotty's Avatar
I stand corrected. GOod to know!
Old Sep 1, 2010 | 03:33 AM
gqraverice's Avatar
You wouldn't be covered under the recall if you're out of warranty correct? Also, isn't the oil consumption recall only for the 05+ models?
Old Sep 1, 2010 | 04:43 AM
caketech's Avatar
yea i'm way outta warranty, but i'll give them a call and see cause i do have an extended warranty.
cmesidewayz
Sep 29, 2015 09:28 PM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
Machine Head
Sep 4, 2015 07:22 PM
UT G35
Sep 3, 2015 03:58 PM
Eomfd
Aug 29, 2015 12:42 AM
