motor removal help
Old Sep 2, 2010 | 12:16 PM
lechols155's Avatar
motor removal help
hi i need to replace a motor in a g35 coupe. how hard is it to remove is there any special tools i will need before i start. i know it will have to be removed from the bottom and i have a lift. it really doesnt look that hard. i already have a new motor.
thanks
Old Sep 7, 2010 | 01:58 PM
Sylvan lake V35's Avatar
I can have my engine and tranny out in 4-5hrs, less if I didn't have turbo piping and turbos to deal with. I take the front end off of the car and slide it out the front.
Old Sep 7, 2010 | 02:02 PM
lechols155's Avatar
is it easier that way then out the bottom?
Old Sep 7, 2010 | 02:08 PM
jwrape's Avatar
Took me about 3-4 hours to pull it out of the front the first time.
https://g35driver.com/forums/g35-cou...ain-broke.html
Pretty simple really. just a nice metric set of tools and you are golden. There might have been a couple star bits in there a long the way. It's really well put in there.
Old Sep 7, 2010 | 02:11 PM
Swivel's Avatar
Moderator
Take Sylvan's advice, he's done this a number of times. Not sure you can even take it out the bottom.
Old Sep 7, 2010 | 02:12 PM
jwrape's Avatar
Yes, front is the way to go. It slides right out.
Old Sep 7, 2010 | 02:29 PM
lechols155's Avatar
sounds good thanks for the advice. looking at the pics once the front is off looks like there is a lot of room
Old Sep 7, 2010 | 03:27 PM
Tollboothwilley's Avatar
Did you just pull the AC compressor off to the side? You have to recharge the system if you do it that way right?
My friend replaced his engine and I helped a bit. Pulled the hood and then pulled it straight out the top after disconnected the trans. Pretty easy as well. Just take your time.
Danielek
May 1, 2022 01:28 PM
magnetism80
Jan 27, 2016 12:57 PM
JLee301
Sep 25, 2015 08:46 PM
TNRocker
Sep 21, 2015 08:36 AM
