Missfire, sputter, hiccup.... Fixed!
Old Sep 5, 2010 | 01:42 PM
usmcgetsome's Avatar
So i bought my used 2003 infinit g35 with 95k on the clock. After about 3 months it started to have a slight misfire at idle. So, i let it slide. About the 8 month it was considerably worse. I started with changing the spark plugs. No change. Month 9 Changed coil packs. No change. Month 10 failed cam sensors 1. So i changed both sensors. Still had the missfire. Cleaned throttle body and upper plenum. Got a little better. Finally changed the pcv and breather hose.
It's finally fixed and purrs very nicely.
Hope this helps someone!
Old Sep 6, 2010 | 05:34 AM
MM_G3520's Avatar
How much was the PCV, and how hard was it to change? Where is it and how do you do it?
Old Sep 6, 2010 | 07:41 AM
Blue Dream's Avatar
I drove ttrank's car solo
Thanks for the inof. PCV replacement isn't something that comes up on this forum very frequently.
Old Sep 7, 2010 | 03:41 PM
Tollboothwilley's Avatar
PCV costs your $11-12 at any NISSAN dealership
it will take 5 min to swap out yourself.
I don't think you need to change the hose - unless you mutilate it. It should have no problems.
Old Sep 8, 2010 | 03:22 PM
thanks tollbooth for posting up the cost. although no one answered the location of the pcv.
You have to take off the engine cover and it's at the forward left of the engine looking from the front of the car. You can goolge it and it will show you what it looks like.
Old Sep 17, 2010 | 08:55 PM
RiversideS13's Avatar
I wonder if you can just clean the PCV instead buying a new one?
Old Sep 17, 2010 | 09:19 PM
Project's Avatar
Its like 15 bux at most why try and clean something that was made to be thrown away.
Old Sep 22, 2010 | 04:05 PM
CBRworm's Avatar
20 Year Member
I would just replace it with OEM. This valve is critical to keeping the engine clean and happy.
Sometimes the hoses do get filled up with crap and need to be cleaned or replaced.
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
NyCrAzY
Oct 1, 2015 09:19 AM
