My engine took a dump WTF!!!!
Old Sep 22, 2010 | 12:45 AM
Canadian's Avatar
Canada, eh?
Originally Posted by GT-ER
I'd say 90% of people can't tell the difference...they both look very similar in color. What is not similar is how they burn. Oil smoke will stay MUCH longer lingering around and will smell AWFUL while coolant smoke will dissipate much quicker and will not smell quite as bad.
True, but I can easily tell the difference after I noticed the awful oil burning smell and blue smoke chugging out of my exhaust for almost a year.
Before I saw blue smoke from oil burning, I did see white smoke from my car and it was pretty easy to tell but some people probably won't know. It is very easy to tell if you pay attention to the smell though.
Old Sep 22, 2010 | 03:53 PM
CBRworm's Avatar
20 Year Member
If the cat material disintigrates, it can get sucked into the exhaust ports and pulled into the engine. It will very quickly eat your motor. This effect allows us to get by without EGR valves.
I don't think this is nissan/infiniti's fault. Bad aftermarket cat (or bad tuning leading to bad aftermarket cat) = damaged engine.
Old Sep 24, 2010 | 09:27 PM
tiguy99's Avatar
That's why HFCs have an off road use only disclaimer when you buy them. Technically they're not legal and guess what OP...
You illegally modified your catalytic converters and now have a damaged motor as a result. That's exactly what the court would say if you tried to sue Nissan/Infinti for your car's problem right now.
I say get your motor looked at and go from there. Maybe the problem isn't as bad as you think
Old Sep 30, 2010 | 10:30 AM
gspotter's Avatar
To the OP, what year is your G? How many miles were on the Crawfords? I have Crawfords on my G and I'm thinking about changing them for Berks. Berks have a metallic substrate instead of ceramic.
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
