DIY Wire Tuck
Old Jan 5, 2011 | 10:43 PM
NFSP G35's Avatar
? = 2B || !2B
Nice job man. It's about time someone took the time to do a writeup
For anyone that hasn't seen the other thread ---> https://g35driver.com/forums/g35-sed...wire-tuck.html
Old Jan 5, 2011 | 11:06 PM
Swivel's Avatar
Moderator
Massive thanks for this, Heist!!
Old Jan 5, 2011 | 11:15 PM
Heist.'s Avatar
NFSP G35- thanks for the link
SwivelHips- np I will try to keep the site up and running even when I leave the community.
Old Jan 5, 2011 | 11:47 PM
Swivel's Avatar
Moderator
Would you mind if someone copied the pics and text and included it in a thread here on Driver (likely this one, but I will look and see if it's appropriate elsewhere)? All credit to you, of course. Then you wouldn't have to worry about maintaining it on G35mods. If you'd rather that didn't happen, just say so, it's completely cool.
Old Jan 6, 2011 | 12:46 AM
TIAN's Avatar
Hold The Line
+1 I have your page as a favorite. Very great and valuable information! If you choose to no longer maintain the page it would be great to have one of us transfer over the info and sticky it here.
Old Jan 6, 2011 | 12:57 AM
Frankieg35's Avatar
Me and my buddy are planning to tackle this.. We are gonna do the headlights wire tuck on Saturday.. His motor is pulled right now can we do the main harness now or does the motor have to be in??
Old Jan 6, 2011 | 06:10 AM
HotRodG35's Avatar
Personally its better to do main harness tuck with engine installed for better seperation of harness.
I would definately due the starter/alternator battery lead cable with engine out, its easier to drill and route cable by shock tower.
Old Jan 6, 2011 | 12:15 PM
Frankieg35's Avatar
Ok kool thanks!! Guess we will get everything else done first before we put the motor in..
Old Jan 6, 2011 | 01:43 PM
sillyoldtayo's Avatar
you guys make it look so easy! great job! looks much cleaner
Old Jan 6, 2011 | 06:46 PM
the_sedan's Avatar
i'll be doing this since it's hella easy obv on our cars once i put my new motor in thankee
Old Jan 9, 2011 | 11:33 PM
TemjinX2's Avatar
great diy
Old Jan 24, 2011 | 05:03 AM
or_G's Avatar
how long does it usually take?
Old Jan 24, 2011 | 05:45 AM
HotRodG35's Avatar
The engine harness can take 1-2 days depending on how quickly you get the Intake plenum rremoved and seperate harness. Engine harness is time consuming. It will take longer if you plan on depinning connectors for smaller wire sleeves.
The wire harness route along fender will take a day for both sides. Depending on how quickly you can remove/install fenders. I found it easier to remove fenders for drilling/routing wires also to mount ground wires to fender support. I extended the driver side headlight harness 6" to keep it out of view from engine bay. Some people don't need to extend headlight harness its all to your preference.
If its your DD I would plan 1 weekend for engine harness and another weekend for both fender harness.
Of course this does not include time for filling and smoothing engine bay after wire tuck, use body plugs and fabricate block off plates for a temporary solution.
Old Jan 24, 2011 | 08:11 AM
GreenGoblin's Avatar
The goblin resurrection
I did a local guys, did both headlight harnesses in a few hours. I would say a day at most if you never did it, I guess if you go ultra slow 1 side a day.
Old Jan 26, 2011 | 12:26 PM
  #30
vp-g's Avatar
wow nice.. so no cut or splice on the oem harnest? where do you buy the wire?
