Can I change my clutch fluid this way???
Old Oct 20, 2010 | 07:57 AM
Theanimedude's Avatar
Hey everyone!
So i want to change my clutch fluid but i dont really want to get under the car and drain it.
I saw on a youtube video where the guy would just suck out the clutch fluid, add new clutch fluid and pump the clutch which would cycle the fluidand then repeat until the clutch fluid shows no more contamination.
The only flaw would be that it would take alot more time than usual right?
Old Oct 20, 2010 | 08:01 AM
MHellmann's Avatar
Better to bleed through
It is better to have someone in the car to pump the clutch pedal as you open and close the bleeder valve. That way you will flush both the master and slave cylinder and all the lines as well. The bleeder valve is easy to reach and it goes pretty quick.
Old Oct 20, 2010 | 08:11 AM
not familiar with that.
could you tell me where that is?
somewhere here?
Old Oct 20, 2010 | 08:29 AM
MHellmann's Avatar
It is on the side of the slave cylinder which is mounted to the side of the tranny right behind the clutch arm. Sorry, you have to get under the car! I just did my sons with him, it's not that bad.
Old Oct 20, 2010 | 08:44 AM
MHellmann's Avatar
Bleeder Valve
Location and instructions
Attached Thumbnails Can I change my clutch fluid this way???-clutchbleed.jpg
Old Oct 20, 2010 | 09:08 AM
intersting. Do you think i need to change my gear fluids too?
so basically i need to attach a tube to the bleeder valve, so as someone pumps the clutch, that is where the old fluid will come out of correct? As as it drains, add the new fluid?
Old Oct 24, 2010 | 11:37 PM
pwebb's Avatar
looks like you need a brake fluid flush too
Old Oct 26, 2010 | 08:51 AM
oh no, thats not my car. i stole taht picture from the DIY clutch and gear fluid remover.
11bEMT
May 27, 2022 03:13 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
bdnbfrank
Aug 17, 2015 02:09 PM
NemesisGee
Aug 11, 2015 07:10 PM
TurboEE
Jul 31, 2015 10:41 AM
