Coolant Problems
My reason for asking is quite simple. You don't just change radiators every year. You obviously have something else causing this problem. Either the fan clutch is not working correctly, or you have something causing too much pressure causing the radiator(s) to fail. It's quite possible that the cap can be stuck closed and making too much pressure for the end tanks.
The radiator was replaced a year ago after I hit a deer.
I don't know what a fan clutch is, but thought it was only on the 2003s, I have a 2004.5. I haven't checked temperatures other than on the dashboard where the needle is always in the middle.
Changed the thermostat about six months ago. I thought the thermostat was causing no heat at idle, but all I had to do was bleed the coolant lines.
My car recently start doing the same thing. Its blow cold air at idle n over heating at times. I tried bleeding out the air with this method.
1 start up car and have the heater blowing @ 90* MAX (in this point its blowing cold air bt the temp needle is setting mid way)
2 rev it to 2000rpm heater is blowing hot air, go out to bleed it, come set in the car and the heater is now blowing cold air again.
3 repeat it which seems endless; with the same results...
What could b the problem...help please.
So drive for a bit, and then try bleeding the air out. REMEMBER the system is under pressure so don't fully remove the screw, just enough to allow air bubbles to come out once it's a solid stream of fluid seal it and drive or let it sit a bit then go again. It's a bit painstaking but it works.
End Tanks are leaking.
IMHO, you need a new radiator.
This time buy a radiator for the MANUAL... the two tubes sticking out of the lower end tanks signify that it was for an Automatic. (no big deal) but just less clutter in the way.
Additionally, begin to investigate: WHY?
Why do you continue to replace radiators? Do you have too much pressure in the system? Is the thermostat sticking?
