Coolant Problems
Old 05-26-2011, 03:50 PM
prinzzz's Avatar
i've got a similar problem as well. Ihave a leakage, i've seen it coming from one of the hose's right around the pic where aaronhl showed. I also hit a deer awhile back but didnt change the radiator. I took it to a mechanic who tested the pressure and said the radiator is fine but it's the hose. I took it to the dealer and they told me it's both radiator and hose. I want to know what's a good cheap radiator for 6mt. Also what hose's are good. any help would be appreciated. damm i wrote a book
  #47
Old 05-26-2011, 04:17 PM
andrewstclair's Avatar
All the after market aluminum radiators are made for the 350z there isn't any made for the G35 that I know of. They work but when you put them in it requires cutting n modding the top mounts on the car OR you can take it into a machine shop and they cut the top posts off the radiator and move them to where they should be on the G35 and re-weld them. That's what I had to go through and a couple buddys did to get ours in. I have a factory rad with fans if your interested if not I can post pics of the rad mod to get the aluminum to fit
  #48
Old 05-26-2011, 04:44 PM
prinzzz's Avatar
is your car 6mt? any leaks and what nots? price? where are you located?
  #49
Old 05-26-2011, 04:49 PM
No leaks the old one cracked this one was put in new and was in for about 9 months then I took it out and went aluminum cuz I did my motor build and supercharger its just been sitting in my garage for the last year I haven't got around to selling it. It is 6MT. I don't know what's fair to charge like maybe 120 plus shipping and I'm in vancouver but I don't mind shipping. I can post pics of it if u want when I get home.
  #50
Old 05-26-2011, 05:03 PM
prinzzz's Avatar
yea please post pics and let me know what the total would amount to including shipping. thanks
  #51
Old 05-26-2011, 05:11 PM
What's your zip code
  #52
Old 05-26-2011, 05:52 PM
prinzzz's Avatar
14216
  #53
Old 05-28-2011, 01:49 AM
AARONHL's Avatar
If your radiator is leaking in the same spot where mine was, you need to replace the radiator. It's not any of the hoses.
I see radiators on eBay for around $100, but don't know their quality.
  #54
Old 05-30-2011, 10:53 AM
prinzzz's Avatar
yea i know. i took a closer look @ it this weekend and it the radiator itself leaking @ the edges.
  #55
Old 05-30-2011, 12:51 PM
Tollboothwilley's Avatar
I found a KOYO replacement (stock size) for $140 brand new - thats what I used about 3 years ago when my tanks were leaking.
  #56
Old 05-30-2011, 01:53 PM
prinzzz's Avatar
where @? send me the link pls
Thebaws11
07-02-2021 11:36 AM
wuzz-upp
10-03-2015 04:21 PM
DRG35R
09-16-2015 05:33 AM
mattdg35
09-14-2015 11:28 AM
AuAltima3.5
Cooling
09-13-2015 10:46 AM
Quick Reply: Coolant Problems
