Overheating Issue
Old Jun 6, 2011 | 11:21 PM
  #46
lsmooth81's Avatar
Originally Posted by DRKNYT
Problem solved. Appreciate everyone who chimed in. I took it to my local mechanic. Apparently, the dealership forgot to tighten the valve back there behind the engine when they replaced the fans so my coolant was leaking out. WTF. The dealership is so ****ty. Almost had to make me replace my whole engine.
That is why I told you that is good practice to check up after them. There were several times that the dealer's mechanic forgot to tighten something or connect something on my car. Glad to hear everything is good to go.
Old Jun 9, 2011 | 04:03 AM
  #47
acee's Avatar
Addict
how many times should you change you antifreeze/coolant fluid in our cars?
Old Jun 9, 2011 | 06:57 AM
  #48
linpointer's Avatar
updatng my status, all i did was add coolant in my car when it got low, has been workin fine for 3 weeks now, even when the weather is hot. Now if i can get my driver side electronic glitches taken care of....
Old Jun 9, 2011 | 11:09 AM
  #49
brandon1978's Avatar
The factory fill is good for 4-5 years, but after the first time you change it, you should change it again every 2-3 years. Don't put any water in it other than distilled.
G35Rican
Jul 31, 2024 01:37 AM
cmesidewayz
Sep 29, 2015 09:28 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
