Stillen Engine Dampener Brace
Old Dec 6, 2004 | 03:12 AM
TedRuxpin's Avatar
Hi, do you live in Dallas? Could you assist me with my install of it? Im not too handy with this kind of stuff.
Old Dec 6, 2004 | 12:32 PM
4mrBMWguy's Avatar
I assume you are directing your question to me? Sorry, I live in Austin. The install was not complex. The most difficult thing was working within the space confines.
To help create working space, use string to tie the ps resevoir out of the way. I removed the one bolt attaching the coolant resevoir so it too could be move up and away for addtional space. And of course make sure you have the appropriate tools.
Hope this helps.
Old Dec 7, 2004 | 03:08 AM
TedRuxpin's Avatar
Okay sounds good. Ill follow the instructions and your suggestions regarding space.
Old Dec 9, 2004 | 08:48 AM
P_Diddy's Avatar
what does this dampener bolt to? I can't tell what that black box is that attaches to the body frame. You are putting the engine's side load into the body frame in a direction that it was not designed for....hmmmm....
Do high-end sports cars have these things already built in?
Old Dec 9, 2004 | 12:19 PM
Profile4's Avatar
thanks for the feedback
Old Dec 11, 2004 | 01:53 PM
TedRuxpin's Avatar
the dampener attaches two places according to the instructions (1) passenger side of timing chaing cover and (2) and to a bracket provided in package over power steering pump bracket. If I get it installed today, I'll attach a picture.
Old Dec 11, 2004 | 06:02 PM
SoCaliG35er's Avatar
I installed the dampener today.. It was a bitch to install since it was soo cramped.. I recommend have a few C wrenchs and allen sockets. I did notice additional vibrations, but it bearable. Overall a good upgrade..
Old Dec 11, 2004 | 06:22 PM
TedRuxpin's Avatar
So after you installed the brace, there were additional vibrations?
What kind of grounding kit do you have?
How do you like the rear strut tower brace? Are you able to still use your trunk?
Old Dec 12, 2004 | 01:07 PM
Yes, there was more vibration esp in the battery area. I need to figure out what is vibrating and secure it.
I made my own grounding kit using high quality audio 9 gauage power cables.
With the rear brace it is definitely stiffer in the rear. Since the brace located in the rear part of the trunk. I was still able to put a set of clubs in the trunk.
Old Dec 14, 2004 | 02:14 AM
TedRuxpin's Avatar
socali,
Could you post a pic of the rear tower brace in your trunk? I am curious to see what it looks like...
Old Dec 14, 2004 | 10:06 AM
CrazyMike's Avatar
Could you snap one of the Stillen dampener too? Can't seem to find a picture of one installed anymore... Thanks!
Old Dec 16, 2004 | 12:51 AM
Stillen Engine Dampener Pics
Here are the pics. Kinda cramped..
Old Dec 16, 2004 | 12:52 AM
Stillen Rear Strut Brace
Here's the pic
Old Dec 16, 2004 | 01:25 AM
TedRuxpin's Avatar
Thanks for posting the pics. I think I'm going to get the rear strut tower brace now. It is far back enough in the trunk. Were you able to install it yourself?
Old Dec 16, 2004 | 02:06 AM
  #30
I was able to install it myself. It was a bitch too. You need to becareful not to tear the trunk coverings while removing it.. As far as tighting the strut bolts. I recommend inserting the bolt from bottom up and used a allen racket socket on one(bottom) end and a C wrench on the other(top)... There's not room to get a allen wrench in there. BTW you will need to drill 2 holes(One on each side of the trunk) into the chassis for the brackets. I used a razor blade to cut a plus shaped hole in the trunk coverings to slide the strut bar through.. It took me about an hour..
Freeman186
Sep 6, 2023 10:07 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
Joe Gargano
Sep 18, 2015 11:17 AM
Jnm07
Sep 5, 2015 01:16 AM
