VQ35DE Rev-Up Cams
Old Jul 29, 2011 | 09:16 AM
R6n350GT's Avatar
Originally Posted by gorillanismosti
Cams sacrifice a little low to increase mid-range & high-end power, in drag applications you want this, and with a good turbine combo is amazing the power that you reach...
Thanks for that!
Is it a good idea to then get solid motor mounts for the extra torque? i got some stainless steel ones off ebay for $50.. dam impulse buy!
Old Jul 30, 2011 | 11:27 AM
gorillanismosti's Avatar
Originally Posted by R6n350GT
Thanks for that!
That is a good mod for people with serious intentions, the only problem with that is you will feel everything under the hood in your dash and hands. That isn't too good for street driving experience isn't very comfortable but if your #1 priority is racing that is the way to go...
Old Jul 30, 2011 | 05:35 PM
R6n350GT's Avatar
Hm ok, i was reading its not as bad as some cars and that its only really a bit of extra noise . Is there some sort of poly rubber you can put on the end so its a semi solid mount? stiffer than stock but not 100% solid?
Old Jul 31, 2011 | 05:51 PM
Sylvan lake V35's Avatar
Most companies make specific cams for the rev-up motors.
here is JWT list they say specifically which motor they are for.
http://www.jimwolftechnology.com/customer_results.asp
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Tmatheso
Dec 13, 2015 03:24 PM
mbe32
Nov 13, 2015 11:09 PM
UT G35
Sep 3, 2015 03:58 PM
