Transmission flush problems, won't flush
Old Sep 5, 2011 | 11:55 AM
2gnt2wrx's Avatar
Ok a few months back I drained and refilled my wife's transmission in her 04. I added the same amount that I took out and moved on to flush the fluid out of the cooler. I plugged the return hose and put a length of hose on the nipple at the bottom of the cooler. I started the car expecting fluid to come out into my drainpan and nothing happened. Stopped and started several times still nothing. Is there a thermostat or something somewhere that would stop it from letting me flush the fluid out? I let it run for 5 minutes and still nothing.
Any ideas? does this procedure need to be done when the engine is hot?
Old Sep 5, 2011 | 03:38 PM
04G35NYC's Avatar
Doing a flush is not recommended with the automatic transmission you can do more harm then good.
Old Sep 5, 2011 | 03:50 PM
2gnt2wrx's Avatar
It's not the same kind of flush, I think you are thinking of the flush where they hook up to the filler neck and force fluid through the system. I'm talking about letting the transmission pump pump fluid through the system on it's own at it's normal operating pressure and speed.
leo38cheng
Nov 12, 2015 06:49 PM
derres
Aug 28, 2015 03:27 PM
saskicker32
Aug 11, 2015 02:12 PM
Phenomenon9
Aug 9, 2015 01:34 AM
newg37
Jul 26, 2015 09:32 AM
