knocking noise in engine
Old Nov 4, 2011 | 01:06 PM
  #31
Zioxx's Avatar
Originally Posted by jibberjabbers
The revised TSB doesn't require a maintenance record. Plus, why would they use the previous owner as an excuse not to warranty it?
I mean, was it burning oil when you bought the car at 24k? Or did it happen at 62k?
Did Infiniti change the oil on your car during your ownership? I guess they didn't bother to check the oil level? Or maybe they KNEW about it, and didn't bother to mention it. Like most of them do. (waiting till you are out of warranty to bring it up).
I would say it started at about 48k.(first time I herd the noise)
I had infiniti change my oil several times but was never told anything
When does the engine warranty expire for something like that?
Im gonna see if I take it to 1 last deal & see how my luck goes..
Old Nov 4, 2011 | 01:09 PM
  #32
Zioxx's Avatar
Originally Posted by slim17265
0w40 is going to burn MORE oil...go here and learn...If that was mine I would try SHELL 15/40...if that does not make a considerable difference in noise or oil usage you need new parts...
www.bobistheoilguy.com
If I last recall isnt Shell 15/40 for diesel engine cars?
You have more information regarding that oil?
Old Jul 3, 2012 | 12:49 PM
  #33
Michaelh90's Avatar
Same thing happen to me. While driving in the expressway i started to hear a knocking sound coming from the engine. The car shut off automatically.. I let it cool down for an hour. After that i turn it on again, and still there i shut off the car. Checked the oil it was almost empty addedd three quarts. Turn it back on and there was no noise. Then i drove a mile and i heard the knocking noise again, then the car shutoff and couldnt turn it on again. No crank at.all. Im getting my engine replace and i dont want this to happen again im wondering if this happens cuz of my cats? I got no check engine light also and i got a 03 6sp.
Old Oct 13, 2018 | 05:09 AM
  #34
TheSqueeky's Avatar
G35 Rev Up 6 spd manual
Mine's doing the same
Hey man did you ever fix the problem because mine is doing the same.
Old Oct 13, 2018 | 10:25 AM
  #35
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you were 3 quarts low on oil and the motor was knocking there's a really good chance you spun a bearing or something that will require a rebuild. When the motor makes those sounds and then shuts off on it's own and won't crank it's usually because the rotating assembly seized.
Or you have a DIFFERENT problem and yours isn't "doing the same".
Old Mar 31, 2020 | 04:27 PM
  #36
Karen Harris's Avatar
Infiniti G35S
2007 Infinti G35S Engine Issues
So I purchased this car about 3 months ago. I had a few issues with fluids leaking but got them all fixed. My son drove the car to town and on the way down a hill it started to have a slight knocking noise but not a rod knocking something quieter. It barely starts then shuts off. I am thinking it is a fuel pump is part of the issue but the knocking noise is weird and you can only hear when you rev up the engine. I have read it could be the anti theft fuse and then the chain tensioner also. I am learning about this car as I go but anyone else having this issue with their G35's. Any advice or ideas that I can check would be great! Thank you for any help! Would be greatly appreciated!
Old Mar 31, 2020 | 04:57 PM
  #37
cleric670's Avatar
BANNED!!!
Is it a sort of "thumping sound" coming from the glove box area? It could be a failing fuel damper.
Record a video of it making the sound, post to youtube, put the link here. An audio picture is worth a thousand words.
Old Sep 8, 2021 | 02:25 PM
  #38
cbarber478's Avatar
g35
Originally Posted by Hatchbackboyz
oh yeah and does any one know what else could lock motor up as far as the top end cams timing chain valves etc..... gettin ready to either replace or fix the existing watever is cheapest and easier let me know please guys thx
I know I’m 10 yrs too late😂 but did you ever figure out the issue have the same problem knocking coming from the top end in the front
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
joedaddy1
Jul 28, 2015 02:58 PM
rping
Jul 26, 2015 09:53 PM
Thaaa_king
Jul 18, 2015 05:56 PM
mjfenix
Jul 17, 2015 02:07 PM
