Blowing out carbon deposits
Old Apr 20, 2012 | 07:01 PM
seymore4's Avatar
m56
also check your plugs
Old Apr 24, 2012 | 07:32 PM
wiredG35's Avatar
finallt got some pics how the %^*(^&T()&*^)(* do post pics dammit!!!!?Lets start from here, factory batt cables soldered, the batt+ has 2 4GA cables now soldered. And of course the 4 main power 10GA cables soldered aswell. This is the ground from the batt soldered to 2 cables to the block and the other splits to main ground and 1 goes inside the cabin for fuel injector ground (M66) behind glove box. This point is 1 foot away from batt ground to body cable and is main ground for passenger ground very important! This is the ground from the battery soldered to the ground to the rest of my system. On the top i have 2 lengths of 8GA car stereo ground cable soldered to a tin plated crimp, that is soldered to another crimp running across the front of the engine. You can see the nice flow connecting both crimps and shinny (done with vice grips) take the bolt out and it is still connected. BTW this is an 06G35X with no mods. The stuff to the right is all 6 coil pack grounds and 2 transmission grounds, bare with me i'm still learning to use this new camera. I will post more and edit blurry pics, after you get the wiring done then you can use the water injection the finishing touch on the carbon problem. this is next.
Old Apr 24, 2012 | 07:34 PM
Tolboothwilley™'s Avatar
you need a host...go to www.photobucket.com - create an account and then upload your pictures...you can then use the IMG link they provide and copy/paste it into a post here
Old Apr 25, 2012 | 06:35 PM
wiredG35's Avatar
I did what you said and now i have posted pics in the previous post. Thanx R in order thank you sir. toolbooth *****
Old Apr 25, 2012 | 09:06 PM
np, here to help
Old May 22, 2012 | 09:43 PM
wiredG35's Avatar
All wiring http://i1145.photobucket.com/albums/...OOBIES::JAMIN:
Picture Share
Feb 4, 2018 12:41 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
master111
Sep 25, 2015 08:32 PM
