How would one fix oil in the spark plug issue
Old Nov 17, 2011 | 09:50 AM
Anton_Chigurh's Avatar
Looking to get an 04 and i see some people that when they change their plugs...they have some oil in there. What is needed to fix this and is it a big issue? Or can you just let it go and keep on going with the new plugs?
Old Nov 17, 2011 | 11:22 AM
blackout2277's Avatar
Spark plug tube seals I believe... U have to take off the valve cover to replace it. Pretty easy though took me about an hour in the dark
Old Nov 17, 2011 | 12:46 PM
So a mechanic could probably do it in less time than that?
Is it a big issue if you don't fix it?
Old Nov 17, 2011 | 02:07 PM
Z1Motorsports's Avatar
Eventually the spark plug tube will fill up and kill that coil pack, if your cheap like i was you can just remove the spark plug every 5k miles or so and let that oil drain into the cylinder lol.
-Rob
Old Nov 17, 2011 | 02:53 PM
will every plug do it..or only certain ones
I mean it may not even happen on this car but just wondering in case it does when i change them
Old Nov 17, 2011 | 05:17 PM
I doubt every one will do it. When I was troubleshooting what ended up being blown piston rings. I was checking out all my coils and plugs. My misfire was in cyl 6 but I had oil pooling up into the tube before it... Worse case scenario just find the part number somewhere on here and replace if you ever go down that road. Trust not at all difficult to get to the valve cover just remembering what screws go where is the toughest part
Old Nov 19, 2011 | 01:04 AM
mikhaelbt189's Avatar
there's R&D factory that actually gives you great deal. they will send you both valve covers which has been modified on the seals for 250. and after replacing yours, send both of yours VC to them and they will send 100 back to you. so pretty much saying 150 for both valve covers, instead 300 each buy from dealership.. there's no way you can have it done in 1 hour. going to mechanic they will charge you around 600 for labor. just do it yourself. is not that hard!
Old Nov 19, 2011 | 01:45 AM
^^ I have a mechanic that is very cheap...doubt it would be $600...more like $200 would be my guess
But if it's not that big of a deal..i may just change the plugs more often then if thats the case
Wonder if i can have my mechanic take out a spark plug to see if theres oil in there when i have him look at it next week before i buy
Old Nov 19, 2011 | 01:48 AM
well good for ya, but you can save 200 bucks for doing it yourself. i got that 600 quote from intec racing in WA.. that's why i told you so
Old Nov 19, 2011 | 02:04 AM
I will F something up..not very handy unfortunately
Terry_G35
May 9, 2020 01:39 AM
yassy
Aug 9, 2015 07:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
ghost_g35
Aug 7, 2015 10:31 AM
Terry_G35
Aug 4, 2015 02:38 PM
