primary timing chain alignment question
Old Nov 1, 2018 | 10:06 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Unfortunately no it DOESNT make sense. Do you have the old chain, lay the two side by side and see if there's a defect on the new chain and maybe THATS what's actually off by one link.
Old Nov 1, 2018 | 10:09 AM
Chris Adams's Avatar
Infiniti fx35
Did you ever get this fixed.
Ok I'll have to take a park again. I'll take any answer to get this car back running this is all hold me up
Old Nov 1, 2018 | 10:35 AM
cleric670's Avatar
BANNED!!!
Maybe it's just a trick of the light but I cannot see your chain alignment mark in the crank sprocket. I just realized all the photos I was looking at in the top of the thread were from a completely different person. Take some photos with good light of both sets of cams, the crank, and a shot of the whole thing with the engine set at TDC so we can see those alignment marks.
Old Nov 1, 2018 | 10:45 AM
Infiniti fx35
I would like to know if the tdc mark on the outer face of the motor and the How Monica balance are also TDC the unpainted mark. ?
Old Nov 1, 2018 | 11:00 AM
cleric670's Avatar
BANNED!!!
Balancer has a different mark on the timing cover.
Old Nov 1, 2018 | 11:05 AM
Infiniti fx35
Yes but it also says that the mark on the A Monica balance on painted mark and the mark on the front of the motor is TDC also. But when I take off the front of the motor it all dont line up so I use the inside mark on motor
Old Nov 1, 2018 | 11:14 AM
cleric670's Avatar
BANNED!!!
Are you reusing existing sprockets?
You line up the UNPAINTED mark on the crank pulley with the TDC indicator on the timing cover, that should be the exact same position as the crank sprocket mark compared to the oil pump.
Old Nov 1, 2018 | 11:21 AM
Infiniti fx35
Nope not the same. When I take it off again I'll take pic and post
Old Nov 13, 2018 | 10:05 AM
Infiniti fx35
Ok got it back together and at first it didnt crank. But I also read that the alarm would make the car not crank. So I maeesed with the buttons and a couple clicks and the car started. And smooth. Need to know how to reset the alarm completely though an ideas?
Old Mar 31, 2022 | 11:52 AM
2k11fx35's Avatar
FX35
Having same issue on my fx35
So, I'm having the same issue. I know it's a long shot since this post is so old but any input would be greatly appreciated. Replaced the timing chains and tensioner on my fx but I'm one tooth off also. I've compared old/new chains and it's not off. I've turned the crankshaft through the harmonic balancer and didn't feel anything hitting.
rezendvous420
May 31, 2020 01:26 PM
Joshua615
Aug 31, 2015 12:29 AM
ghost_g35
Aug 7, 2015 10:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
itschuckster
Jul 25, 2015 08:07 AM
