Help, car won't start!!! Bad cam/crank sensor? Please help me diagnose
Old Jan 27, 2012 | 02:09 AM
EverybodyWildOu's Avatar
Okay my car is cranking strong but isn't starting. I've been doing some research and have been wondering if it's the infamous cam and/or crank sensors. BUT I don't have any codes being thrown though.
However lately I've had issues where the car wouldn't start until a couple after a couple of tries. The car would also have some issues with drivability and has died a couple of times in the past while driving. I would then pop start it. At times the idle would be a little rough too.
The car is getting fuel. I can hear the pumps prime. I'm pretty sure it isnt the security system because the security light is off when I try and start it. It has a new battery. I also hear the throttle body opening and closing so I think it's good. I also changed the plugs recently but I'll check them and also check for spark.
So any theories or troubleshooting ideas? Thanks in advance guys.
I should mention my car has a built block and twins. It also has an HKS Fcon.
Old Jan 27, 2012 | 02:17 AM
Polishthrust's Avatar
is your check engine light on?
Old Jan 27, 2012 | 02:18 AM
Nope no codes man.
Old Jan 27, 2012 | 02:23 AM
crankshaft and camshaft sensors usually set off check engine.
Old Jan 27, 2012 | 02:37 AM
I literally have no codes unfortunately. If I pull them, I was hoping someone can give me the values for resistance if I checked them with a multimeter. I hear the service manual has them.
Old Jan 27, 2012 | 09:28 AM
Any other suggestions anyone?
Old Jan 27, 2012 | 09:37 AM
JaE35's Avatar
Moderator
G35 Sedan
Alternator? Those sensors would throw a code
Old Jan 27, 2012 | 10:26 AM
Well here's the thing guys. I don't know if my car is capable of throwing codes. I know the car has the GTM flash and the Fcon controls everything. A good example is that the 02 sensors and a bunch of other systems don't even show up anymore if I try and go through inspection. And I have no codes or CELs.
I would like to test the sensors with a multimeter but was hoping someone has the values for the resistances.
Old Jan 27, 2012 | 10:29 AM
JaE35's Avatar
Moderator
G35 Sedan
ahh i see, you should buy those cheap cam sensors from auto zone and see what happens...probably what it is unless its an o2 sensor
Old Jan 27, 2012 | 05:21 PM
UCIMAplaya2's Avatar
Its almost surely your cam position sensors or crank Ps. I would replace both cam sensors. They are fairly cheap ajd easy. Alternator wont cause this and a car can still run with all bad o2 sensors but it will run like **** in a limp mode.
Old Jan 28, 2012 | 02:56 AM
in that case i would start with the crankshaft sensor. They go for about $30
Old Jan 28, 2012 | 04:44 AM
Well okay friends I had enough time to pull the passenger sensor and it had oil on it. I was wondering if this is normal or not?
Old Jan 28, 2012 | 06:47 AM
Blue Dream's Avatar
I drove ttrank's car solo
Yep that's normal.
Old Jun 5, 2012 | 11:27 AM
nadjkovic's Avatar
Yes that's normal because your heads need oil. Sorry for the thread revival, but I'm having almost the exact same issue, and I'd love for you to post what the fix was!!
Here's my thread: https://g35driver.com/forums/engine-...wont-idle.html
Old Jun 12, 2012 | 01:54 AM
Tolboothwilley™'s Avatar
Non-start issues are often from lack of communication from ECU to the Key.
Sensors going bad often exhibit symptoms before going out.
