Aluminum Radiators: Koyo vs. Mishimoto vs. Blackworks
Old Apr 6, 2013 | 04:59 PM
  #61
guitarrocker98's Avatar
Anyone.....
Old Apr 7, 2013 | 12:02 AM
  #62
Lone Wolf's Avatar
From all the people I have seen with KOYO radiators, they have all reported that their fitment was 100%.
Old Apr 7, 2013 | 01:19 AM
  #63
Awesome. I'm still in the air because I've heard fitment was fixed on all of them.
Old Apr 8, 2013 | 12:16 AM
  #64
Tolboothwilley™'s Avatar
i haven't installed my Mishimoto yet - but this week or next I plan to. I wanna get it in before the summer starts up here in vegas. I'll confirm after I get it done
Old Apr 9, 2013 | 10:35 AM
  #65
I would GREATLY appreciate it before I pull the trigger on anything. Im seriously looking into the koyo, because they are kinda the best of the best, and I am turbo'd. I just dont want anything to go wrong. Though with overheating I would have ample time to fix it.
Old Apr 11, 2013 | 06:13 PM
  #66
VatoVazq's Avatar
Do you guys know if the Mishimoto radiator has the transmission connections for the 5AT. Ive been looking it up but cant find a clear yes. i dont want to buy a separate transmission cooler.
Old Apr 15, 2013 | 05:45 PM
  #67
Deepdiver's Avatar
I concur and have heard this as well..
Old Apr 15, 2013 | 08:54 PM
  #68
ryanm8's Avatar
Mishimoto makes radiator models with the transmission lines. I think only the older models didn't have them. Make sure it specifically says it's for a 5AT before you buy it, though.
I have a Mishimoto currently. Fitment was not perfect but I got it to work. I had to buy adapters from Home Depot to get the transmission lines to hook up properly, so keep that in mind.
Old Apr 16, 2013 | 05:53 PM
  #69
they have 2 different versions - if you get the MMRAD-G35-03 then it will have connections for the automatic trans cooler
Old Apr 20, 2013 | 02:28 AM
  #70
VatoVazq's Avatar
I ended up ordering the Mishimoto and it was not a perfect fit. Fits really tight and i had to leave out the bottom rubber boots that go on the radiator legs because it was too tall. Then i ran into the issue of the radiator cap hitting. I had to shave into that black piece that goes across our engine bays. I didnt realize that the connections were wrong until the last thing to do was hook up the transmission lines haha i tried the home depot connections but it was leaking fluid and i ended up working the hose all the way onto the connection and buying special clamps to secure them on. i got it to work and im pretty happy so far but its not a simple swapping of parts.
Old Apr 20, 2013 | 10:16 AM
  #71
ryanm8's Avatar
I had those same problems.... I was still able to use the boots though, but it was a really tight fit.
I would keep an eye on your transmission lines. The threads on there will make the hose start leaking over time, I would think. I was able to keep it from leaking with some fittings and Teflon tape.
Old Apr 20, 2013 | 05:11 PM
  #72
VatoVazq's Avatar
Ha I thought about that but I was so frustrated by that point I didn't want to take longer. Did u use any particular Teflon tape? cus since there's going to be hot transmission fluid pumping through it makes me nervous.
Old Apr 20, 2013 | 05:55 PM
  #73
ryanm8's Avatar
No, just the teflon tape from Home Depot. The transmission fluid shouldn't be much over 200 degrees F, so it won't be a problem. I've had it installed on my car for about 9 months now with no leaks.
Old Apr 20, 2013 | 06:15 PM
  #74
VatoVazq's Avatar
Oh okay nice.yeah Im going to do it also then. The fittings I tried are the 1/4 in adapter. What size adapter/fitting did you use?
Old Apr 20, 2013 | 06:59 PM
  #75
Hmmmmmmm...... This is making me lean to the koyo. But ams has a great deal too..... But I know lots who have had problems with the ams leaking at some point.
