Motor swap help
Old Oct 5, 2012 | 01:48 PM
Gcouped05's Avatar
Motor swap help
Hello everyone i have picked my brain apart til it hurts figured it was time to reach out for some help so to start out i have a 05 g35 coupe i spun a rod bearing so here is my issue icame across a 05 350z wrecked with 40k on it turbonetics single turbo kit some nice suspension parts i swapped the motor trans harness bcm ecu what can i do about getting the dash Harness to work all my problems im guessing ly within tge bcm due to pins not matching up my obd port has no power turn the key off gauge cluster stays lit up someone please help save this g
Old Oct 6, 2012 | 01:43 AM
jmisencik's Avatar
Please use some punctuation. It seems all morning, almost every post I attempt to read has no punctuation!
Old Oct 6, 2012 | 01:55 AM
Gcouped05's Avatar
Here we go grammer **** just like every other forum I am far from a english teacher i am seeking help not criticism
Old Oct 6, 2012 | 05:32 AM
jmisencik's Avatar
I am sorry you feel that way, not trying to be an @ss, but I bet more people would actually read your post and help you if you used some punctuation. To use a period you don't need to be an English teacher...that is like 2nd grade English basics...
Old Oct 6, 2012 | 01:13 PM
Sylvan lake V35's Avatar
Take out the 350Z ECU and wiring harness put the G35 stuff back in. The only thing you need to swap is the engine and turbo kit. Then go get an Up-rev tuner and get an ECU tune for the turbo kit.
Old Oct 6, 2012 | 01:30 PM
Gcouped05's Avatar
The 350z has different cam sensors so i would have to run the 350z engine harness or are you talking about my dash harness
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
thechitoguy
Oct 1, 2015 05:25 PM
doakley92
Sep 25, 2015 12:58 PM
